[surface handling] Problem Loading Surfaces for entry
Old   March 8, 2020, 01:09
Default Problem Loading Surfaces for entry
David Vazquez
davidvzq is on a distinguished road
Good day,
I am trying to run a simple tutorial I found online for "snappyHexMesh", however, when trying to run the second step of the tutorial, which is to run the command "surfaceFeatureExtract", I get the following error:
Problem loading surface(s) for entry: cylinder.stl
What does this mean? In the tutorial it runs just fine.
I am using OpenFOAM v1912.
I wanted to attach the case file but it was to big for the forum. Below is the link to the tutorial I am following.
https://www.youtube.com/watch?v=oc4V79F78AQ
Thank you all for your help.
Bests,
David Vazquez.
davidvzq is offline   Reply With Quote
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 19:41
problem with loading udf in fluent 6.3 James Fluent UDF and Scheme Programming 6 January 22, 2015 05:51
[General] problem with pvpython when loading state involving Plot Over Lines hadrien51 ParaView 1 October 17, 2012 11:18
problem in loading a udf roop_windscar Fluent UDF and Scheme Programming 3 March 22, 2012 08:26
Multiple Sahdows / Periodicity Problem Michael Pi FLUENT 0 July 11, 2005 07:42
