[Salome] Body Fitting error
Old   February 26, 2020, 03:58
Post Body Fitting mesh importing error
cal
saidc. is on a distinguished road
Hi, I'm trying to import a "body fitting" mesh with using "ideasUnvToFoam". I have a simple geometry (250k Nodes) like the attachment. When i meshing with "NETGEN-1D-2D-3D" everythings is fine but "body fitting" doesn't working. Why i am getting this error, how can i fix it?
Salome V-8.4.0
OpenFoam-7
ERROR
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7-1ff648926f77
Exec   : ideasUnvToFoam mesh250k.unv
Date   : Feb 26 2020
Time   : 10:37:22
Host   : "said"
PID    : 6245
I/O    : uncollated
Case   : /home/said/OpenFOAM/openfoam7/tutorials/denemeler/pitzDeneme1
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:"  SI: Meter (newton)"
unitType:2
Unit factors:
    Length scale       : 1
    Force scale        : 1
    Temperature scale  : 1
    Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 237034 points.
Processing tag:2412
Starting reading cells at line 474091.
First occurrence of element type 115 for cell 1 at line 474092
Read 117336 cells and 0 boundary faces.
Processing tag:2467
Starting reading patches at line 708766.
For group 1 named inlet trying to read 0 patch face indices.
--> FOAM Warning :
    From function void readSets(Foam::IFstream&, Foam::DynamicList<Foam::word>&, Foam::DynamicList<Foam::List<int> >&)
    in file ideasUnvToFoam.C at line 559
    Reading "mesh250k.unv" at line 708768
    When reading patches expect entity type code 8
    Skipping group code -1
--> FOAM FATAL IO ERROR:
Attempt to get back from bad stream
file: IStringStream.sourceFile at line 0.
    From function bool Foam::Istream::getBack(Foam::token&)
    in file db/IOstreams/IOstreams/Istream.C at line 56.
FOAM exiting
saidc. is offline   Reply With Quote
body fitting, mesh, netgen, salome
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
