[snappyHexMesh] Layer Mesh Either Too Thin or Produces Error Cells
Old   February 24, 2020, 18:03
Red face Layer Mesh Either Too Thin or Produces Error Cells
Nian
noodleluvmay is on a distinguished road
I have been encountering some problems when it comes to adding layers to mesh, I wonder if you would be able to help. I am using version 18.10.
My problem is that a lot error cells appear when I tried to increase the layer cell thicknesses. The reason I want to do that was because I thought having a very big size/thickness difference between 2 adjacent cells might result in inaccurate results (image as attached, layers are really thin comparing to neighbouring cells).
So ideally I would want the layers to expand gradually till the thickness reaches the adjacent cell size.
As far as I understand, basically all the cells snappyHexMesh meshes are cubic cells, so it seems to be impossible to have surrounding cells to have a higher aspect ratio (flatter). And so this is also why I would like to have final layer cells to be quite thick.
But snappyHexMesh does not seem to like that, once the setting for thickness had gone past a certain value, number of erroneous cells would increase dramatically. I have tried to alter some of the other values in the control dictionary, but have not found one that seemed to be solving the issue. (Meshing error attached)
Below is my code for layering in snappyHexMesh in the dictionary:
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes false;
    // Per final patch (so not geometry!) the layer information
    layers
        surface1
            nSurfaceLayers 5;
    // Expansion factor for layer mesh
		expansionRatio 1.15;
		finalLayerThickness 0.0001;
		minThickness 0.00002;
    nGrow 0;
    featureAngle 130;
    slipFeatureAngle 30;
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 10;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 10;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 80;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
If anyone would have any suggestions in solving this, I would very much appreciate it! Thank you!
Nian
noodleluvmay is offline   Reply With Quote
Old   February 25, 2020, 07:56
john myce is on a distinguished road
Hi Nian,
In addLayers control you have a lot of combination :
Expansion ratio + finalLayerThickness
Expansion ratio + firstLayerThickness
thickness (overall) + firstLayerThickness
thickness (overall) + finalLayerThickness
Expansion ratio + thickness (overall)
maybe in your case you can try to specify the last & the overall thickness
Also by default, minThickness is set to 1% (relativeSize) to the cell near the layer. Does your absolute size verify this value (1%) ?
Cheers,
john myce is offline   Reply With Quote
layer addition, snappyhesmeshdict
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] Meshing a very thin meatus with SnappyHexMesh enginpower OpenFOAM Meshing & Mesh Conversion 29 September 9, 2017 04:46
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[snappyHexMesh] Improving prism mesh me3840 OpenFOAM Meshing & Mesh Conversion 2 April 2, 2014 05:37
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
