[blockMesh] Creating blockMeshDict from python
Like Tree23Likes
Old   August 12, 2021, 18:25
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
Originally Posted by dlahaye View Post
Greetings,
Question: revolve with angle equal to 180 degrees or larger does not work, correct? This has to do with face orientation, correct?
Edit: I would like to revolve over 360 (full circle) degrees? How do I concatenate 4 revolves each over 90 degrees taking as base the result of the previous operation? How do i merge pairs at the end?
Edit again: found cylinder as building block. Will look into this first. Thx!
Thanks, Domenico.
Revolve is an operation that works on a single block. blockMesh probably won't let you build such a block.
What's planned next:
- a revolve on a collection of faces, creating multiple blocks
- a loft/elbow or something where you can also specify number of blocks in the lofted/revolved direction. this would allow you to create, for instance, a 360 degree torus from <n> blocks. you can do that now but you have to manually create those segments.
www.damogranlabs.com
kandelabr is offline   Reply With Quote
Old   August 13, 2021, 17:56
Domenico Lahaye
dlahaye is on a distinguished road
Attached what I managed to build thus far. Thanks again!
kandelabr likes this.
dlahaye is offline   Reply With Quote
Old   August 15, 2021, 19:10
Domenico Lahaye
Greetings again.
Is there a function that allows to set in the file constant/polymesh/boundary the patch type entries for wall to "wall" instead of "patch" (as currently is the case)?
Doing in manually is a bit of burden.
Cheers, Domenico.
Old   August 16, 2021, 16:04
kandelabr's Avatar
Nejc
No as there is no real need for that - just use the createPatch utility. Here's a sample system/createPatchDict that does just that. Also note that you can leave the most numerous faces out of the classy_blocks script - blockMesh will name them defaultFaces and you can capture them all with createPatch. Saves you quite a lot of lines of code!
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync false;
// Patches to create.
patches
        name walls;
        patchInfo
            type wall;
        constructFrom patches;
        patches (defaultFaces);
dlahaye likes this.
Old   August 22, 2021, 16:26
Domenico Lahaye
Greetings again.
Question: is there an easy way to easily obtain doubly graded meshes (see e.g. Section 2.6 https://openfoamwiki.net/index.php/B..._blockMeshDict) using classy_blocks, other then editting the blockMeshDict file?
Thanks, Domern
Old   August 23, 2021, 06:09
kandelabr's Avatar
Nejc
As of this moment, unfortunately not. More sophisticated grading functions will be added later. If your geometry isn't too complicated and you don't want to edit grading, you can add more simple-graded blocks...
Old   August 23, 2021, 07:59
Domenico Lahaye
Thanks!
I will edit blockMesh to facilitate my simulations.
Best wishes, Domenico.
Old   August 30, 2021, 17:09
Francisco T
frantov is on a distinguished road
Thanks for the python code!
I agree! Blockmesh with topoSet and createPatch utilities are very powerful.
frantov is offline   Reply With Quote
Old   September 10, 2021, 09:51
Francisco T
Greetings
I'm trying to build a geometry which has a cavity inside.
Similar to the attached image.
I guess I can figure out how to model the features outsid but I'm wondering about the cavity. The right image is a cut to see inside. How can we define a cavity?
Old   September 10, 2021, 11:46
kandelabr's Avatar
Nejc
you need to slice your model into blocks. unfortunately with cavities, the number of blocks increases rapidly... but that's all i can help.
Unless you decide to use snappy/cfMesh and use blocks just to create geometry (inside): https://damogranlabs.com/2020/10/blo...xternal-flows/
Old   September 10, 2021, 17:01
Francisco T
Thanks for your reply!
I want to avoid the stl creation for this case, therefore I think I will use blockMesh and a combination of
topoSet + subsetMesh commands to delete internal elements and create the cavity.
Cheers
Old   July 10, 2023, 11:19
Pedro Gouveia
unilord is on a distinguished road
Hey,
I am working in Ubuntu 22.10, and I want to start using classy blocks to try and mesh the geometry in the atached picture. It is a turbopump, composed of a dual blade inducer, a radial impeller and a volute. The picture shown is of the fluid domain, not the actual pump solid.
https://imgur.com/a/WpltVGL
First question is, do you think that is doable or worth the time?
Second question, and excuse me for the ignorance. I can't get the examples to run in the python script. It is giving me the following error:
ModuleNotFoundError: No module named 'classy_blocks'
when I copy the https://github.com/damogranlabs/classy_blocks into the examples folders, it gives me this new error
So, could you please do a quick explanation/guide on how to proceed to the setup of classy blocks on ubuntu?
unilord is offline   Reply With Quote
Old   July 10, 2023, 17:11
kandelabr's Avatar
Nejc
Hi, thank you for your interest in classy_blocks.
In fact, this whole thing started because I needed a better mesh for a centrifugal pump. I first wrote a simple script that tracked block points for me, then expanded it to what it is now. I do use classy_blocks to create a mesh of an impeller as part of my job so I can tell it is doable but cannot share the code. For me it was a huge success because I need a proper parametric model for automatic optimization but it took me around a year to whip it up (besides other nuisances I'm responsible for ). Can't imagine working without this now, though.
I use classy_blocks to to create a background mesh for a volute that fits inlet AMI ring and outlet mesh is oriented with the flow, but the spiral geometry is meshed with snappy. A volute can be meshed with pure-hexa blocks but at the moment I have no idea how. It's on my TODO list, though.
Inducer is probably the easiest part but also most probably not worth the time. Just use snappy and feed it a cylindrical background mesh.
About the examples: you probably didn't install the package correctly: see https://github.com/damogranlabs/clas...#how-to-use-it
You can PM me if you decide to dive into this... but you have been warned
Old   July 11, 2023, 05:13
Pedro Gouveia
Hey, thank you for the quick reply.
Honestly, after reading your point of view, I don't think it is worth the time at the moment. Mostly because I am working on my master thesis in partnership with a rocket company, so both me and them want to finish this kind of fast.
I liked your sugestion of the cylindrical background mesh. This is my first big CFD project, so I didn't even think about that possibility. I will implement that and let you know, in a few days/weeks how it turned out.
Thank you
Old   July 11, 2023, 05:20
Pedro Gouveia
One question, the way you explained the stuff gave me the understanding that, usually, you mesh the components seperately. Is that right? If so, how do we make sure that the elements share the nodes between each other?
Old   July 11, 2023, 06:58
kandelabr's Avatar
Nejc
Yeah, if you need one mesh promptly, you need an automatic mesher. Try snappy and cfMesh, they will do the job.
In turbomachinery and other moving machinery you can't keep nodes together so static and moving mesh parts must be coupled in another way, AMI (ESI-CFD version), NCC (Foundation version) or GGI (foam-extend).
See the
incompressible/pimpleFoam/RAS/propeller
tutorial or similar to see what it looks like.
[blockMesh] Created a python package for generating blockMeshDict grokkingStuff OpenFOAM Meshing & Mesh Conversion 3 November 5, 2020 08:55
[blockMesh] Creating a blockmeshDict file andrewlindsay OpenFOAM Meshing & Mesh Conversion 8 August 15, 2020 10:56
[blockMesh] Creating an axisymmetric piston cylinder in blockMeshDict foadsf OpenFOAM Meshing & Mesh Conversion 9 August 23, 2018 08:54
[blockMesh] what commands should I use to start creating a blockMeshdict file? Hojae OpenFOAM Meshing & Mesh Conversion 1 November 12, 2014 17:58
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
