[Gmsh] gmshToFoam wrong token type - expected word error
Old   December 31, 2019, 17:00
Angry gmshToFoam wrong token type - expected word error
TheOneBird
TheOneBird is on a distinguished road
I am trying to convert a gmsh file to foam using the gmshToFoam utility. When I run the command I receive the following error:
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 0 the variable $MeshFormat
file: IStringStream.sourceFile at line 0.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
    in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
The gmsh file be found here: https://gofile.io/?c=I77hRb
Also, the start of the gmsh file is as follows:
$MeshFormat
2.2 0 8
$EndMeshFormat
$PhysicalNames
21
3 1 "mesh"
2 2 "b2-periodic_1deg"
2 3 "b3-periodic_1deg"
2 4 "b4-periodic_1deg"
2 5 "b5-periodic_1deg"
2 6 "b6-periodic_1deg"
2 7 "b7-periodic_1deg"
2 8 "b8-subsonic_inflow_pt"
2 9 "b9-farfield_riem"
2 10 "b10-viscous_solid"
2 11 "b11-back_pressure"
2 12 "b12-singular_axis"
2 13 "b13-viscous_solid"
2 14 "b14-singular_axis"
2 15 "b15-viscous_solid"
2 16 "b16-farfield_riem"
2 17 "b17-farfield_riem"
2 18 "b18-to-stitch-a"
2 19 "b19-to-stitch-b"
2 20 "b20-to-stitch-a"
2 21 "b21-to-stitch-b"
$EndPhysicalNames
$Nodes
36994
1 -7.7389998436000e+00 0.0000000000000e+00 0.0000000000000e+00
2 -7.7390034604200e+00 9.5725001104946e-05 1.0968998657738e-02
3 -7.7390078108300e+00 2.1736027395078e-04 2.4907020378070e-02
Some help on this would be fantastic. Thanks!
TheOneBird is offline   Reply With Quote
Old   December 31, 2019, 17:25
mzzmrt is on a distinguished road
I have imported your file via gmshToFoam with OpenFOAM 4.1 in Linux and no problem with the .msh file.
Here is the result:
https://ibb.co/TYjVyPv
mzzmrt is offline   Reply With Quote
Old   December 31, 2019, 17:35
TheOneBird
Thanks for the quick reply mzzmrt.
Well that is certainly strange... I might have to change my OpenFOAM version to fix this. I am using OpenFOAM-dev (current version). If it is not too much of a problem, is there any chance you could upload the files/directory of the result of the gmshToFoam?
[edit]: I have fixed it by installing OpenFOAM5 additionally to OpenFOAM-dev. Thanks again!
Thank you heaps!
Old   December 31, 2019, 17:53
Here it is:
https://gofile.io/?c=guCFkj
gmshtofoam problem, openfoam 1806
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
