[blockMesh] Velocity,Pressure locked in Blocks |
December 30, 2019, 15:01 |
Tobias R
Rep Power: 6 |
i want to do a simulation like the tutorial/incompressible/icoFoam/elbow but with my own Geometry. The trouble by my simulation is the inlets in the System are locked in the Blocks who have the Inletpatches. And so the hole system reaches its convergenz after s few seconds and no flow through the system. If anyone know a possible reason, i would be thankful. Pls ignore the commentaries in the Codes, btw, they are German. Thankfully Newbie Tobi BlockMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1.0; // convertToMeters: 1m * scale = [Einheit] vertices ( (0 0 0) //0 - unten, rechtes Ufer, Startpunkt (20 0 0) //1 - unten, rechtes Ufer, gegenüber ende Auslasswand1 (7) (35 0 0) //2 - unten, rechtes Ufer, gegenüber ende Auslasswand2 (8) (50 0 0) //3 - unten, rechtes Ufer, gegenüber Buhnenkopf1 (14) (60 0 0) //4 - unten, rechtes Ufer, gegenüber Buhnenkopf2 (15) (200 0 0) //5 - unten, rechtes Ufer, Endpunkt (0 180 0) //6 - unten, linkes Ufer, Startpunkt (20 180 0) //7 - unten, linkes Ufer, ende Auslasswand1 (35 180 0) //8 - unten, linkes Ufer, ende Auslasswand2 (50 180 0) //9 - unten, linkes Ufer, Buhnenwurzel1 (60 180 0) //10 - unten, linkes Ufer, Buhnenwurzel2 (200 180 0) //11 - unten, linkes Ufer, Endpunkt (20 200 0) //12 - unten, anfang Auslasswand1 (35 200 0) //13 - unten, anfang Auslasswand2 (50 120 0) //14 - unten, Buhnenkopf1 (60 120 0) //15 - unten, Buhnenkopf2 (0 0 1) //16 - oben, rechtes Ufer, Startpunkt (20 0 1) //17 - oben, rechtes Ufer, gegenüber ende Auslasswand1 (23) (35 0 1) //18 - oben, rechtes Ufer, gegenüber ende Auslasswand2 (24) (50 0 1) //19 - oben, rechtes Ufer, gegenüber Buhnenkopf1 (30) (60 0 1) //20 - oben, rechtes Ufer, gegenüber Buhnenkopf2 (31) (200 0 1) //21 - oben, rechtes Ufer, Endpunkt (0 180 1) //22 - oben, linkes Ufer, Startpunkt (20 180 1) //23 - oben, linkes Ufer, ende Auslasswand1 (35 180 1) //24 - oben, linkes Ufer, ende Auslasswand2 (50 180 1) //25 - oben, linkes Ufer, Buhnenwurzel1 (60 180 1) //26 - oben, linkes Ufer, Buhnenwurzel2 (200 180 1) //27 - oben, linkes Ufer, Endpunkt (20 200 1) //28 - oben, anfang Auslasswand1 (35 200 1) //29 - oben, anfang Auslasswand2 (50 120 1) //30 - oben, Buhnenkopf1 (60 120 1) //31 - oben, Buhnenkopf2 (35 120 0) //32 - unten, Buhne links (35 120 1) //33 - oben, Buhne links (200 120 0) //34 - unten, Buhne rechts (200 120 1) //35 - oben, Buhne rechts (20 120 0) //36 - unten, Flussmitte (20 120 1) //37 - oben, Flussmitte (0 120 0) //38 - unten, mitte Einlass (0 120 1) //39 - oben, mitte Einlass ); blocks ( hex (0 1 36 38 16 17 37 39) (20 120 1) simpleGrading (1 1 1) // 1 Haupt hex (38 36 7 6 39 37 23 22) (20 60 1) simpleGrading (1 1 1) // 2 Haupt hex (1 2 32 36 17 18 33 37) (15 120 1) simpleGrading (1 1 1) // 3 Haupt hex (36 32 8 7 37 33 24 23) (15 60 1) simpleGrading (1 1 1) // 4 Haupt hex (7 8 13 12 23 24 29 28) (15 20 1) simpleGrading (1 1 1) // 5 Auslass hex (2 3 14 32 18 19 30 33) (15 120 1) simpleGrading (1 1 1) // 6 Haupt hex (32 14 9 8 33 30 25 24) (15 60 1) simpleGrading (1 1 1) // 7 Haupt hex (3 4 15 14 19 20 31 30) (10 120 1) simpleGrading (1 1 1) // 8 Haupt // hex (14 15 10 9 30 31 26 25) (10 60 1) simpleGrading (1 1 1) // 9 Buhne hex (4 5 34 15 20 21 35 31) (140 120 1) simpleGrading (1 1 1) // 10 Haupt hex (15 34 11 10 31 35 27 26) (140 60 1) simpleGrading (1 1 1)// 11 Haupt ); edges ( ); boundary ( Wall_right { type wall; faces ( (0 1 17 16) // rechtes Ufer, 1 Haupt (1 2 18 17) // rechtes Ufer, 2 Haupt (2 3 19 18) // rechtes Ufer, 3 Haupt (3 4 20 19) // rechtes Ufer, 4 Haupt (4 5 21 20) // rechtes Ufer, 5 Haupt ); } Wall_left { type wall; faces ( (7 6 22 23) // linkes Ufer, 1 Haupt (12 7 23 28) // Auslasswand1 (8 13 29 24) // Auslasswand2 (9 8 24 25) // linkes Ufer, 3 Haupt (14 9 25 30) // Buhnenwand1 (15 14 30 31) // Buhnenkopf (10 15 31 26) // Buhnenwand2 (11 10 26 27) // linkes Ufer, 5 Haupt ); } inletOne { type patch; faces ( (13 12 28 29) // Kraftwerk Auslass ); } inletTwo { type patch; faces ( (6 38 39 22) // Fluss, Block 1 (38 0 16 39) // Fluss, Block 2 ); } outlet { type patch; faces ( (5 34 35 21) // Fluss, Block 10 (34 11 27 35) // Fluss, Block 11 ); } frontAndBackPlanes { type empty; faces ( (16 17 37 39) // 1 Block, oben (39 37 23 22) // 2 Block, oben (17 18 33 37) // 3 Block, oben (37 33 24 23) // 4 Block, oben (23 24 29 28) // 5 Block, oben (18 19 30 33) // 6 Block, oben (33 30 25 24) // 7 Block, oben (19 20 31 30) // 8 Block, oben //(30 31 26 25) // 9 Block, oben (20 21 35 31) // 10 Block, oben (31 35 27 26) // 11 Block, oben (1 0 38 36) // 1 Block, unten (36 38 6 7) // 2 Block, unten (2 1 36 32) // 3 Block, unten (32 36 7 8) // 4 Block, unten (8 7 12 13) // 5 Block, unten (3 2 32 14) // 6 Block, unten (14 32 8 9) // 7 Block, unten (4 3 14 15) // 8 Block, unten //(15 14 9 10) // 9 Block, unten (5 4 15 34) // 10 Block, unten (34 15 10 11) // 11 Block, unten ); } ); mergePatchPairs ( ); // ************************************************************************* // controlDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application icoFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 250; deltaT 1.0; writeControl timeStep; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; // ************************************************************************* // p Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { Wall_right { type zeroGradient; } Wall_left { type zeroGradient; } inletOne { type zeroGradient; } inletTwo { type zeroGradient; } outlet { type fixedValue; value uniform 0; } frontAndBackPlanes { type empty; } } // ************************************************************************* // U Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { Wall_right { type noSlip; } Wall_left { type noSlip; } inletOne { type fixedValue; value uniform (6 0 0); } inletTwo { type fixedValue; value uniform (0 -10 0); } outlet { type zeroGradient; } frontAndBackPlanes { type empty; } } // ************************************************************************* // fvSchemes Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************************************* // fvSolution Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.05; } pFinal { $p; relTol 0; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 3; nNonOrthogonalCorrectors 3; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object transportProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // nu 0.01; // ************************************************************************* // |
December 30, 2019, 17:17 |
Herpes Free Engineer
Rep Power: 13 |
Is there any reason why 'inlet2' has -10 m/s inflow speed?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 31, 2019, 08:27 |
Tobias R
Rep Power: 6 |
Hi HPE,
with a low inlet like -0.5 the flow don't leave the first Block so i was trying what happends, if i make the flow faster. But also, sadly i switch the inlets between blockMeshDic and U. I corrected U but the Problem ist still subsits. With a low inlet flows the convergenz is reached after 1sec: Code:
inletOne { type fixedValue; value uniform (0 -1 0); } inletTwo { type fixedValue; value uniform (2 0 0); } |
[Commercial meshers] fluent3DMeshToFoam | bego | OpenFOAM Meshing & Mesh Conversion | 31 | August 16, 2023 09:04 |
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 03:13 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
