[snappyHexMesh] SnappyHexMesh inlet Errors
Old   December 23, 2019, 10:58
Default SnappyHexMesh inlet Errors
Gabriel de Souza Berestinas
gberestinas is on a distinguished road
Dear Master Foamers,
Please, I need some help to understand and solve the problems with my pipe inlet mesh. First I thought that the problem was my mesh resolution in SHM, but after a long attempt of settings, I couldn't figure out what was going on even with a high-resolution SHM mesh.
I set a fixed input velocity on two inlets and the simulation runs very well in Salome's hexahedral mesh. But when I tried to run SHM mesh I got bad results on the inlet face. See attached pictures.
I also tried to change my *.stl resolution and files. But nothing happens.
My sequence:
- blockMesh
- surfaceFeatureExtract
- decomposePar
- run snappyHexMesh -parallel
- reconstructParMesh
Pictures:
1- SnappyHexMesh error (Pressure)
2 - "
3 - Salome's Mesh results (Pressure)
4 - *.stl file inlet.
Thanks.
gberestinas is offline   Reply With Quote
inlet bc, mesh error, snappyhexmesh
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
snappyhexmesh inlet divergence olhe0002 OpenFOAM Running, Solving & CFD 1 November 27, 2009 13:39
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
