[blockMesh] topoSet in Parallel
Old   December 11, 2019, 16:54
Default topoSet in Parallel
shima
shimakasaei is on a distinguished road
Hi all,
I want to refine my mesh using topoSetDict files, so I want to use 'topoSet -dict <location address>' for this part. I would like to know how I can run this command in parallel as in 'topoSet --help' it shows that topoSet can be run in parallel.
I already tried 'mpirun -np 32 topoSetDict1 <address> -parallel' however it stops with an error at the end:
31 more processes have sent help message help-mpi-btl-openib-cpc-base.txt / no cpcs for port
[zagros:01971] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
I would appreciate any help.
shimakasaei is offline   Reply With Quote
Old   December 12, 2019, 12:56
Luis Eduardo
lebc is on a distinguished road
Hi Shima,
Usually I have these lines in my Allrun file:
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
runParallel topoSet
If it is going to work or not depends on what you want to do and which other commands you are running.
lebc is offline   Reply With Quote
Continuing a parallel job with dnamic mesh and topoSet hconel OpenFOAM 0 November 25, 2019 04:54
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
