December 9, 2019, 03:49 |
fluent3DMeshToFoam
Milad Alborzi
Rep Power: 6 |
hi
i am new at working with OpenFOAM, and i want to import a 2D geometry into openFoam. i draw the geometry in Ansys Design Modeler, i generated the mesh with Ansys Mesh and finally i exported as *.msh . i entered "fluent3DMeshToFoam *.msh" in order to convert it, but i faced following massage in the terminal. // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Dimension of grid: 2 Number of points: 3931 Number of faces: 7585 Number of cells: 3655 --> FOAM Warning : Found unknown block of type: "3010" on line 14 --> FOAM FATAL ERROR: Do not understand characters: on line 15 From function virtual int yyFlexLexer::yylex() in file fluent3DMeshToFoam.L at line 763. FOAM exiting // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // also i am using a windows version of the terminal. can anyone help me? thanks |
December 9, 2019, 08:40 |
Rep Power: 15 |
Did you export your Mesh as ascii-File? There is a systemoption in Ansys to export as ascii and not as binary.
December 10, 2019, 01:42 |
Milad Alborzi
Rep Power: 6 |
December 10, 2019, 01:53 |
Milad Alborzi
Rep Power: 6 |
December 10, 2019, 02:31 |
Rep Power: 15 |
In Ansys Meshing: Extras->Options->Meshing->Export For Fluent *.msh select ASCII
September 29, 2020, 11:21 |
Sumit Peh
Rep Power: 8 |
fluentmeshtofoam, openfoam |
fluent3DMeshToFoam creates additional boundaries i didnt specify. | Archoncomando | OpenFOAM Pre-Processing | 0 | January 13, 2019 09:25 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
fluent3DMeshToFoam - (periodic) cyclic boundary | cyln | OpenFOAM Running, Solving & CFD | 0 | October 1, 2017 23:19 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
OpenFOAM command from inside MATLAB | sega | OpenFOAM Post-Processing | 18 | September 25, 2012 07:35 |
