[snappyHexMesh] [Helyx OS] Layers appear in mm, not in m
Old   December 5, 2019, 06:32
Default [Helyx OS] Layers appear in mm, not in m
anonymous
kim0304 is on a distinguished road
I am trying to create a good mesh with Helyx OS and am importing my geometry in mm.
When I add Layers on my outside faces:
(Number of Layers: 3
Layer Stretching: 1.25
Final Layer Thickness: 0.4)
no layers appear, but when I import the geometry in m with the same layers settings (and scale the base mesh and the material point accordingly) the layers appear.
I have checked the relativeSizes in the SnappyHexMeshDict and it is true.
What can I do to have the layers appear in mm?
Thank you!
kim0304 is offline   Reply With Quote
Old   December 6, 2019, 08:46
anonymous
After searching all over the Internet I found the response to my problem here: https://www.simscale.com/forum/t/how...ll-models/9187
I had to change the min. vol of faces from 1E-13 to 1E-21 because I am dealing with really small geoemtries
helyx-os, layers, snappyhesmeshdict
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] Collapsing layers RomCFD OpenFOAM Meshing & Mesh Conversion 5 January 18, 2020 02:39
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh Rohith Giridhar ANSYS Meshing & Geometry 3 June 29, 2015 18:52
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
Layers and turbolence in Interfoam danvica OpenFOAM Running, Solving & CFD 0 April 30, 2012 04:11
