[blockMesh] Submerged deck in wave tank blockMesh |
December 4, 2019, 14:09 |
Conor
I have created a blockMesh for a submerged deck within a wave tank, for use with waves2Foam, and it is coming up with an error, --> FOAM FATAL ERROR: face 0 in patch 2 does not have neighbour cell face: 4(3 19 23 7) From function Foam::labelList FoamlyMesh::facePatchFaceCells(const faceList&, const labelListList&, const faceListList&, Foam::label) const in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 118. After looking over the blockMesh, it is the "object" that is causing issues. the blockMesh is, /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( //lower case front ( 0 -0.6 0 ) //0 ( 8 -0.6 0 ) //1 ( 12 -0.6 0 ) //2 ( 20 -0.6 0 ) //3 //mid1 case front ( 0 -0.3 0 ) //4 ( 8 -0.3 0 ) //5 ( 12 -0.3 0 ) //6 ( 20 -0.3 0 ) //7 //mid2 case front ( 0 -0.25 0 ) //8 ( 8 -0.25 0 ) //9 ( 12 -0.25 0 ) //10 ( 20 -0.25 0 ) //11 //top case front ( 0 0.4 0 ) //12 ( 8 0.4 0 ) //13 ( 12 0.4 0 ) //14 ( 20 0.4 0 ) //15 //lower case back ( 0 -0.6 0.1 ) //16 ( 8 -0.6 0.1 ) //17 ( 12 -0.6 0.1 ) //18 ( 20 -0.6 0.1 ) //19 //mid1 case back ( 0 -0.3 0.1 ) //20 ( 8 -0.3 0.1 ) //21 ( 12 -0.3 0.1 ) //22 ( 20 -0.3 0.1 ) //23 //mid2 case back ( 0 -0.25 0.1 ) //24 ( 8 -0.25 0.1 ) //25 ( 12 -0.25 0.1 ) //26 ( 20 -0.25 0.1 ) //27 //top case back ( 0 0.4 0.1 ) //28 ( 8 0.4 0.1 ) //29 ( 12 0.4 0.1 ) //30 ( 20 0.4 0.1 ) //31 ); blocks ( hex (0 1 5 4 16 17 21 20) ( 50 60 1 ) simpleGrading (1 1 1) hex (1 2 6 5 17 18 22 21) ( 50 60 1 ) simpleGrading (1 1 1) hex (2 3 11 10 18 19 27 26) ( 50 60 1 ) simpleGrading (1 1 1) hex (4 5 9 8 20 21 25 24) ( 50 60 1 ) simpleGrading (1 1 1) hex (6 7 11 10 22 23 27 26) ( 50 60 1 ) simpleGrading (1 1 1) hex (8 9 13 12 24 25 29 28) ( 50 60 1 ) simpleGrading (1 1 1) hex (9 10 14 13 25 26 30 29) ( 50 60 1 ) simpleGrading (1 1 1) hex (10 11 15 14 26 27 31 30) ( 50 60 1 ) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 4 20 16) (4 8 24 20) (8 12 28 24) ) wall bottom ( (0 1 17 16) (1 2 18 17) (2 3 19 18) ) patch outlet ( (3 19 23 7) (7 23 27 11) (11 27 31 15) ) patch atmosphere ( (12 13 29 28) (13 14 30 29) (14 15 31 30) ) wall object ( (5 6 22 21) (6 10 26 22) (10 9 25 26) (9 5 21 25) ) empty frontBack ( (0 1 5 4) (4 5 9 8) (8 9 13 12) (1 2 6 5) (5 6 10 9) (9 10 14 13) (2 3 7 6) (6 7 11 10) (10 11 15 14) (16 17 21 20) (20 21 25 24) (24 25 29 28) (17 18 22 21) (21 22 26 25) (25 26 30 29) (18 19 23 22) (22 23 27 26) (26 27 31 30) ) ); mergePatchPairs ( ); |
December 4, 2019, 17:13 |
Herpes Free Engineer
Rep Power: 13 |
Are you using v1.5? a.k.a. the version before Justin Bieber was born.
could you also please attach the complete blockMesh log file?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 5, 2019, 06:05 |
#3 | |
Conor
I am a university student and this is the versions recommended by my lecturer. no log file is created when running blockMesh in the terminal, but the full message is as follows; /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : blockMesh Date : Dec 05 2019 Time : 11:01:43 Host : "conor-U" PID : 2991 Case : /home/conor-u/OpenFOAM/conor-u-4.1/applications/utilities/waves2Foam/tutorials/Case/waveFlume nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/conor-u/OpenFOAM/conor-u-4.1/applications/utilities/waves2Foam/tutorials/Case/waveFlume/constant/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks Creating topology patches Reading patches section Creating block mesh topology Reading physicalType from existing boundary file Default patch type set to empty --> FOAM FATAL ERROR: face 0 in patch 2 does not have neighbour cell face: 4(3 19 23 7) From function Foam::labelList Foam:olyMesh::facePatchFaceCells(const faceList&, const labelListList&, const faceListList&, Foam::label) const in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 118. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam:olyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const at ??:? #3 Foam:olyMesh::setTopology(Foam::List<Foam::cellS hape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ??:? #4 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:? #5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:? #6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Aborted (core dumped) |
Pressure for wave height in an Water Wave Tank | Cluain | CFX | 8 | December 6, 2021 03:58 |
Simulating numerical wave tank and calculating wave load on vertical cylinder | Amit B | FLUENT | 0 | July 27, 2019 09:56 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
WAVE TANK star-ccm+ . wave height dampens. WHY? | muhsin | STAR-CCM+ | 3 | October 9, 2012 13:24 |
active wave absorb(about wave tank) | zhaochuangang | ANSYS | 0 | September 22, 2010 02:29 |
