December 4, 2019, 11:04 |
meshing smoothness problem
Bill Lasher
Rep Power: 17 |
I am meshing a sector of a cylinder using snappyHexMesh and have a problem with mesh quality near the surface. The full model is attached as well as a close-up of a section in an area where I am having a problem. I am getting "hot spots" of velocity and nut (using twoPhaseEulerFoam) in areas where there is a large jump in mesh size. These areas appear in other places on the model, all of which are near the top surface. Any thoughts on how to fix this?
December 4, 2019, 17:18 |
Herpes Free Engineer
Rep Power: 13 |
- could you please attach the log file of `checkMesh -allGeometry -allTopology`?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 4, 2019, 17:47 |
Bill Lasher
Rep Power: 17 |
Sure, here it is. Looks like there are some problems.
December 4, 2019, 17:52 |
Rep Power: 13 |
- don't mind `concave` related stats. but `tet`-related stats is worrying.
- during your mesh generation via SHM, alter mesh quality settings for `tet`, and redo the meshing - reduce the refinement nearby edges. if you would like resolve the edges, consider to use SHM's `feature edge` functionalities, which will help to snap onto the given edges in a better way
December 5, 2019, 08:41 |
Bill Lasher
Rep Power: 17 |
Thanks. I was using the default meshQualityDict.cfg and it had minTetQuality set to -1E30. I changed it to 1E-15 and it got rid of the bad tet messages, but the problem of hot spots and quick mesh changes is still there. I've attached a new logfile from checkMesh.
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
Gambit meshing problem to following geometry | ahmadmln | ANSYS Meshing & Geometry | 2 | October 21, 2014 01:49 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
