November 18, 2019, 17:10 |
meshing with Salome
anonymous
Rep Power: 7 |
I'm had some issues when meshing with snappyhexmesh so I've decided to try Salome.
I was hoping for some advice though.. After importing a STEP file and creating my groups I run into a problem trying to create a 3D mesh. If you look at the attached picture you'll see that Salome doesn't give me the option to create a 3D mesh. Is this because my geometry isn't air tight? Any advice would be greatly appreciated. |
November 21, 2019, 06:14 |
Rep Power: 16 |
It is some time ago that I have used 3D meshes with salome so I might be wrong with my assumption. I believe salome only recognizes the shell of your geometry, and hence, offers only surface meshes. To create a 3D mesh, you would need a volume of the inside.
meshing 3d, salome |
Salome cgns format mesh to SU2 | JPBLourenco | SU2 | 19 | November 18, 2019 03:11 |
[Other] Salome Meshing | seanmike31 | OpenFOAM Meshing & Mesh Conversion | 3 | August 8, 2015 01:09 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 07:44 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
