[snappyHexMesh] Error: Cannot find face 165412 in any of the patches 1(rocket_scaled)
Old   November 16, 2019, 14:24
Default Error: Cannot find face 165412 in any of the patches 1(rocket_scaled)
Kjersti Bragstad
Xaxte is on a distinguished road
We tried to generate a mesh around an imported geometry (stl.file) with snappyHexMesh. It says that it generated a mesh that was ok, and it looks ok in paraview. But when we run the rhoPimpleFoam solver we get the following error message:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7-6ef561967074
Exec   : rhoPimpleFoam
Date   : Nov 16 2019
Time   : 18:33:36
Host   : "kjersti-VirtualBox"
PID    : 3426
I/O    : uncollated
Case   : /home/kjersti/OpenFOAM/kjersti-7/run/prism
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
        Calculations will do 2 corrections
PIMPLE: Operating solver in transient mode with 2 outer correctors
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
Creating field dpdt
Creating field kinetic energy K
No MRF models present
No finite volume options present
Courant Number mean: 0.000372342 max: 0.0298496
Starting time loop
Time = 5e-09
PIMPLE: Iteration 1
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 1.87371e-07, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 7.07998e-08, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 4.96554e-07, No Iterations 1
smoothSolver:  Solving for e, Initial residual = 1, Final residual = 2.6378e-07, No Iterations 2
smoothSolver:  Solving for p, Initial residual = 1, Final residual = 7.11171e-07, No Iterations 1
time step continuity errors : sum local = 8.63045e-12, global = -2.41024e-12, cumulative = -2.41024e-12
PIMPLE: Iteration 2
smoothSolver:  Solving for Ux, Initial residual = 2.91336e-05, Final residual = 1.51895e-08, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.00102276, Final residual = 6.36141e-07, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 1.53354e-05, Final residual = 5.23964e-09, No Iterations 1
smoothSolver:  Solving for e, Initial residual = 0.00015063, Final residual = 1.26379e-07, No Iterations 1
smoothSolver:  Solving for p, Initial residual = 2.38202e-05, Final residual = 1.62645e-10, No Iterations 1
time step continuity errors : sum local = 1.61197e-13, global = 1.98876e-14, cumulative = -2.39035e-12
--> FOAM FATAL ERROR:
It seems your patches are not consistent with the mesh : internalFaces:158590  total number of faces:191060
    From function Foam::label Foam::polyBoundaryMesh::whichPatch(Foam::label) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 747.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::polyBoundaryMesh::whichPatch(int) const at ??:?
#3  void Foam::fvMatrix<double>::setValuesFromList<Foam::UList>(Foam::UList<int> const&, Foam::UList<double> const&) at ??:?
#4  Foam::epsilonWallFunctionFvPatchScalarField::manipulateMatrix(Foam::fvMatrix<double>&) at ??:?
#5  Foam::fvMatrix<double>::boundaryManipulate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary&) at ??:?
#6  Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
#7  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
Aborted (core dumped)
The constant/polyMesh/boundary file is this
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "1.5e-08/polyMesh";
    object      boundary;
1
    rocket_scaled
        type            wall;
        inGroups        1(wall);
        nFaces          20066;
        startFace       170994;
Have any of you experienced something similar or know what could be wrong? Attached is a picture of the mesh. If you need any more files, just tell me!
Thank you so much for your help, it would be highly appreciated!
Xaxte is offline   Reply With Quote
fatalerror, openfoam, openfoam7, rhopimplefoam, snappyhexmesh
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
