[blockMesh] blockMesh face consistency Error
Old   November 15, 2019, 20:21
Question blockMesh face consistency Error
siefer92 is on a distinguished road
Howdy Yall:
I'm having an issue with blockMesh. I am meshing a circular cylinder, like the potential foam example, and I've created my blocks and preliminary mesh.
(I've attached a labeling blocking diagram)
While going to refine I stumbled on to the stupid: Inconsistent number of faces between block pair Error.
I know the error results from improper cellular consistency between blocks, but what makes this error strange for me is that I am certain I am refining the mesh correctly.
Don't take my word for it though, attached is my default block Mesh file. With a dimensionaly consistent distribution of cells between each block.
(10 10 1). The resulting mesh is attached as a picture.
When I refine the back 4 blocks, 14 13 12 & 11, to say (200 10 1) the resulting mesh is refined without error and is attached below.
When I go to refine blocks 4 3 2 & 1 in a near similar manner, (40 10 1). I get the error: Inconsistent number of faces between block pair 0 and 1
The problem is that the error complains about block pair 0-1, despite me not touching the cell count in Y or Z direction and the interface between these cells lays in the Y-Z plane. If the axis of refinement is perpendicular to shared face, then the refinement shouldn't alter its nFaces count correct?
So, I'm sure I am making an incredibly stupid mistake, but I am not quite certain where it exists.
Thanks for yalls assistance!
siefer92 is offline   Reply With Quote
Old   November 18, 2019, 10:39
Default more files
here is my blockMesh file and a picture of the mesh with a refined tail section
blckMesh.txt
EDIT***********
After disappearing for the weekend, my brain did some unconscious work... BlockMesh axes are defined x0-> x1 =(x) x1->x2 = (y) and Z is normal to the plane formed by x0 x1 x2 x3. My Assumption was that when block 0 was created this defined the axes and all subsequent blocks would just fall into that scheme. I was incorrect. The use of isotropic grading and cells per-dimension made it more difficult to spot my error. I will go redefine all block according to the block0 scheme and return with an update.
blockmesh, inconsistent, mesh error
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
