[Commercial meshers] Openfoam mesh convergence problem |
November 13, 2019, 21:46 |
Zhengwei Long
Rep Power: 7 |
I used the buoyantBoussinesqSimpleFoam to calculate the airflow in a complicated rooom.
If I used the gambit tri mesh, the solver would be ok. But I used the tri mesh from the other software, such as Starccm, the solver has convergence problem,such as the turbulence k error. I check the mesh quality. Actually, the quality of the mesh from the Starccm is better than the mesh from gambit. I also tried to change the fvScheme, fvSolution, problem still the same. Anyone who has the same experimence? Thanks |
[Commercial meshers] Problem with cyclic boundaries in Openfoam 2.3, mesh import from ICEM | Scabbard | OpenFOAM Meshing & Mesh Conversion | 29 | October 6, 2020 22:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[Commercial meshers] Problem with export unstructured mesh in OpenFOAM | AdrianoCT | OpenFOAM Meshing & Mesh Conversion | 2 | June 24, 2015 04:56 |
Convergence problem with Stage, refined mesh | pugovka9085 | CFX | 2 | June 2, 2015 02:32 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 03:28 |
