[Salome] Unwanted face inside a geometry made with IdeasUnvToFoam |
November 8, 2019, 10:01 |
20mioMeshGiant
Dear CFD-Online users
I have a terrible problem with mesh made in Salome, converged to OF format via IdeasUnvToFoam. After the conversion I can see an additional, unwanted face inside the internal cells. It means I have a totally unnecessary face in the middle of a valve which should be empty inside. Please see the attached photo. Do you have any ideas how to deal with this problem? It would be perfect to make them "transparent" in terms of boundary conditions, so the faces don't have any specific boundary conditions or even becomes part of internal mesh. I tried to make them "empty" but it solves the case in only one direction. Any tips how to get rid of this face "defaultFaces"? Last edited by HelpMeWithThisMeshGuysPlx; November 9, 2019 at 08:29. |
November 10, 2019, 05:29 |
Damian Berghof
Rep Power: 11 |
Dear HelpMeWithThisMeshGuysPlx,
there is no attached photo! And usually such magic faces are being created by human hand in Salome (based on personal experience). Can you upload please some pictures showing your Salome model or even upload your entire Salome model, if possible? I can investigate it. best, Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups https://bit.ly/2lFfDkQ https://bit.ly/2k2u8Pj |
November 10, 2019, 06:03 |
20mioMeshGiant
Thank you for your Reply, Damian
this is the .py file made with Salome (just the extension changed to .txt) Best Regards EDIT: case solved Last edited by HelpMeWithThisMeshGuysPlx; November 12, 2019 at 10:42. |
ideasunvtofoam, openfoam, salome |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
