[snappyHexMesh] Mesh for CHTMultyRegion
Old   October 25, 2019, 06:42
Default Mesh for CHTMultyRegion
Carlo_P
Carlo_P is on a distinguished road
Hey Guys,
I have a problem...
I would like to simulate a liquid (air) that is coming inside a metal block.
See the first picture.
I would like to use chtMultiRegionFoam.
I have a problem in the mesh, sicne I would like to create two region, using snappyHexMesh.
For the moment, I created the two stl file and put in triSurface.
Then I created the blockMesh..bigger than the metalblock.
In the snappy I linkd the two stl but I'm have a problem to identify them.
Whre I to put the point inside?
Should be inside all the geometry?
BlockMeshDict
xMinGeo     -0.0421 ;
xMaxGeo     0.0579;
yMinGeo     -0.168923;
yMaxGeo       0.0310771;
zMinGeo       -0.121122;
zMaxGeo     0.173878;
xMin #calc   "$xMinGeo-0.05";
xMax #calc  "$xMaxGeo+0.05";
yMin #calc  "$yMinGeo-0.05";
yMax #calc  "$yMaxGeo+0.05";
zMin #calc  "$zMinGeo-0.05";
zMax #calc  "$zMaxGeo+0.05";
deltax 0.01;
deltay 0.01;
deltaz 0.01;
lx #calc "$xMax - $xMin";
ly #calc "$yMax - $yMin";
lz #calc "$zMax - $zMin";
xcells #calc "round($lx/$deltax)";
ycells #calc "round($ly/$deltay)";
zcells #calc "round($lz/$deltaz)";
vertices
    ($xMin $yMin $zMin) // 0
    ($xMax $yMin $zMin) // 1
    ($xMax $yMax $zMin) // 2
    ($xMin $yMax $zMin) // 3
    ($xMin $yMin $zMax) // 4
    ($xMax $yMin $zMax) // 5
    ($xMax $yMax $zMax) // 6
    ($xMin $yMax $zMax) // 7
blocks
    hex (0 1 2 3 4 5 6 7) ($xcells $ycells $zcells) simpleGrading (1 1 1)
edges
boundary
(   Inlet_1
        type wall;
        faces
            (0 4 7 3)
    Outlet_2
        type wall;
        faces
            (2 6 5 1)
    Wall_3
        type wall;
        faces
             (4 5 6 7)
    Wall_4
        type wall;
        faces
           (0 3 2 1)
    Inlet_4
        type wall;
        faces
            (1 5 4 0)
    Outlet_5
        type wall;
        faces
            (3 7 6 2)
Sanppy:
 FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object snappyHexMeshDict;
    castellatedMesh true;
    snap true;
    addLayers off;
    geometry
      Stampo
        type triSurfaceMesh;
        file "geo.stl";
        regions
            Res1     { name Res1;     }
            Res2     { name Res2;     }
            Res3     { name Res3;     }
            Res4     { name Res4;     }
            Fronte    { name Fronte;    }
            Retro   { name Retro;    }
            Box    { name Box;    }
            Blocco   { name Blocco;    }
    Fluido
        file "fluido.stl";
        regions
            Inlet_1    { name Inlet1;     }
            Inlet_2   { name Inlet2;     }
            Outlet_1     { name Outlet1;     }
            Outelt_2    { name Outlet2;     }
    castellatedMeshControls
        features
            file "geo.eMesh";
            levels ((0.001 2));
            refineFeatureEdgesOnly false;
            file "fluido.eMesh";
            levels ((0.001 2));
        refinementSurfaces
        Stampo
            level (2 2);
            regions
                Res1     { level (2 2); patchInfo { type wall; } }
                Res2    { level (2 2); patchInfo { type wall; } }
                Res3     { level (2 2); patchInfo { type wall; } }
                Res4     { level (2 2); patchInfo { type wall; } }
                Blocco  { level (5 6); patchInfo { type wall; } }
                Fronte  { level (2 2); patchInfo { type wall; } }
                Retro { level (2 2); patchInfo { type wall; } }
                Box { level (1 2); patchInfo { type wall; } }
            //faceZone fluidToMetal;
            cellZone Stampo;
            cellZoneInside insidePoint;
            insidePoint (-0.03 -0.15  0.16);
//this point is inside the metal geometry but outside the fluid one.
             //(-0.0421 -0.168923 -0.121122) (0.0579 0.0310771 0.173878)
             //(-0.00826 -0.0979466 -0.121122) (0.00488 -0.0439466 0.173878)
        Fluido
            level (2 2);
            regions
                Inlet1     { level (2 2); patchInfo { type patch; } }
                Inlet2    { level (2 2); patchInfo { type patch; } }
                Outlet1     { level (2 2); patchInfo { type patch; } }
                Outlet2     { level (2 2); patchInfo { type patch; } }
            cellZone Fluido;
            cellZoneInside inside;
            //insidePoint (0.001 -0.0525005 0.001);
            //(-0.00826 -0.0979466 -0.121122) (0.00488 -0.0439466 0.173878)        }
        refinementRegions
        //(-0.075 -0.1 -7.06971e-015) (0.075 0.1 0.306854)
        locationInMesh (0.001 -0.0525005 0.001);
//this point is inside the fluid, but outside the metal
        maxLocalCells 100000;
        maxGlobalCells 2000000;
        minRefinementCells 0;
        nCellsBetweenLevels 2;
        resolveFeatureAngle 5;
        allowFreeStandingZoneFaces true;
        planarAngle 30.0;
        maxLoadUnbalance 0.1;
    snapControls
        nSolveIter 3;
        nSmoothPatch 3;
        tolerance 0.5;
        nRelaxIter 3;
        nFeatureSnapIter 3;
        implicitFeatureSnap false;
        explicitFeatureSnap true;
        multiRegionFeatureSnap false;
    addLayersControls
        layers
            Body
                nSurfaceLayers 3;
                expansionRatio 1.25;
                finalLayerThickness 0.8;
        relativeSizes true;
        expansionRatio 1.1;
        minThickness 0.25;
        nGrow 0;
        featureAngle 130.0;
        slipFeatureAngle 30.0;
        nRelaxIter 10;
        nSmoothSurfaceNormals 1;
        nSmoothNormals 3;
        nSmoothThickness 5;
        maxFaceThicknessRatio 0.5;
        maxThicknessToMedialRatio 0.3;
        minMedialAxisAngle 90;
        nBufferCellsNoExtrude 0;
        nLayerIter 3;
        nRelaxedIter 3;
    /*meshQualityControls
        maxNonOrtho 65.0;
        maxBoundarySkewness 20;
        maxInternalSkewness 4;
        maxConcave 80.0;
        minFlatness 0.5;
        minVol 1.0E-13;
        minTetQuality 1.0E-15;
        minArea -1.0;
        minTwist 0.02;
        minDeterminant 0.001;
        minFaceWeight 0.05;
        minVolRatio 0.01;
        minTriangleTwist -1.0;
        nSmoothScale 4;
        errorReduction 0.75;
        relaxed
            maxNonOrtho 75;
       // minVol 1.0E-20;
    meshQualityControls
        maxNonOrtho 65.0;
        maxConcave 80.0;
        minFlatness 0.5;
        minVol -1.0E-30;
        minArea -1.0;
        minTwist 0.02;
        minFaceWeight 0.05;
        minVolRatio 0.01;
        nSmoothScale 4;
        relaxed
            maxNonOrtho 75;
       minVol -1.E-30;
    debug 0;
    mergeTolerance 1.0E-5;
    autoBlockMesh false;
Carlo_P is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
