[blockMesh] Non-orthogonal cells checkMesh
Old   October 23, 2019, 13:18
Default Non-orthogonal cells checkMesh
Nat K
nskelly is on a distinguished road
I am simulating the flow within a cone-plate rheometer (see attached image for geometry). The red region is the fluid which I am simulating and is being meshed using blockMesh. I tried to create the mesh in blocks using an O-grid method.
I am able to mesh the geometry, however, I tend to get a large mesh non-orthogonality value (89) and there are several non-orthogonal faces when I use checkMesh (see below). I have viewed the areas where this occurs I can see these occur at the truncated region as it is a very small region compared to the size of the domain. How can I reduce the non-orthogonality in this region?
checkMesh log
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            30220000
    internal faces:   29780000
    cells:            10000000
    faces per cell:   6
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       2
Overall number of cells of each type:
    hexahedra:     10000000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch               Faces    Points   Surface topology
    airInterface        40000    40800    ok (non-closed singly connected)
    plate               200000   200401   ok (non-closed singly connected)
    cone                200000   200401   ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.02 -0.02 0) (0.02 0.02 0.0006983)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (-3.56487e-17 -2.98897e-17 -2.97265e-15) OK.
    Max cell openness = 1.33522e-15 OK.
    Max aspect ratio = 177.943 OK.
    Minimum face area = 8.74406e-13. Maximum face area = 1.09776e-08.  Face area magnitudes OK.
    Min volume = 9.2687e-19. Max volume = 9.87975e-14.  Total volume = 5.7744e-07.  Cell volumes OK.
    Mesh non-orthogonality Max: 89.2769 average: 9.76535
   *Number of severely non-orthogonal (> 70 degrees) faces: 84000.
    Non-orthogonality check OK.
  <<Writing 84000 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 0.437164 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Thanks
nskelly is offline   Reply With Quote
block mesh, non orthogonal
[blockMesh] Create internal faces as patch in blockMesh m.delta68 OpenFOAM Meshing & Mesh Conversion 14 July 12, 2018 15:43
[snappyHexMesh] sHM too many cells Knapsack OpenFOAM Meshing & Mesh Conversion 2 July 8, 2017 08:41
[snappyHexMesh] snappyHexMesh Segmentation Fault avd28 OpenFOAM Meshing & Mesh Conversion 11 May 11, 2015 21:32
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
