[mesh manipulation] Cylinder mesh - need for suggestions
Old   October 22, 2019, 13:45
Smile Cylinder mesh - need for suggestions
Maveryck Andres
Maveryck is on a distinguished road
Hi everyone
currently I'm working on turbulence simulation with k-epsilon model over a cylinder channel. I'm getting a wird plot for all the variables and I'm pretty sure is because of the mesh, as you can see on the attached images the wird values of variable k are exactly located over the edges of the central block so I suspect there has to be a better way to mesh.
Any suggestion will be welcome
Maveryck is offline   Reply With Quote
Old   October 23, 2019, 02:47
Damian Berghof
virengos will become famous soon enough
Hi Maveryck,
can you provide some more details?
- boundary conditions, model definition?
- geometry size, dimensions and scaling ok ?
best,
Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups
https://bit.ly/2lFfDkQ
https://bit.ly/2k2u8Pj
virengos is offline   Reply With Quote
Old   October 23, 2019, 05:46
Carlo_P
Carlo_P is on a distinguished road
Hey Maverick,
take a look here:
https://sites.google.com/site/snappy.../cylinder-case
Carlo_P is offline   Reply With Quote
Old   October 23, 2019, 12:14
Maveryck Andres
Originally Posted by virengos View Post
Hi Maveryck,
best,
Damian
It is a quite simple case, cyclic on the inlet and outlet with the following boundary conditions (it is worth mentioning that yPlus at the walls is 0.2 approximately):
Epsilon boundary conditions
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.6;
boundaryField
    inlet
        type            cyclic;
    outlet
        type            cyclic;
    FixedWalls
     type     zeroGradient;
k boundary conditions
internalField   uniform 0.05;
boundaryField
    inlet
        type            cyclic;
    outlet
        type            cyclic;
    FixedWalls
     type     fixedValue;
     value     uniform 1.0e-08;
U boundary conditions
internalField   uniform (0.1 0 0);
boundaryField
     inlet
        type            cyclic;
    outlet
        type            cyclic;
    FixedWalls
        type            noSlip;
The domain is a pipe with diameter = 0.1m and length = 0.1m and bulk velocity is fixed to 1.9 m/s through a momentumSource:
momentumSource
    type            meanVelocityForce;
    active          yes;
    selectionMode   all;
    fields          (U);
    Ubar            (1.9 0 0);
blockmesh, cylinder domain, mesh
[blockMesh] 3-D Mesh in a cylinder Nikunj.R OpenFOAM Meshing & Mesh Conversion 32 July 9, 2023 14:22
[blockMesh] Cylinder mesh using blockMesh with m4 macro Lewis Liang OpenFOAM Meshing & Mesh Conversion 2 November 21, 2017 03:28
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
