October 22, 2019, 09:21 |
Dynamic Mesh
Bill
Rep Power: 7 |
If I want to refine the mesh to simulate melting (solid to liquid phase) on the attached powder bed mesh, do I use dynamicMeshDict? I'm assuming this is the mesh tool that will allow me to add/delete cells to account for the melting phenomenon. Here's what I have, but when I run my simulation, nothing changes in the mesh. Is there some command I am supposed to input before I run my simulation? I'm using OpenFOAM-v1812 and using the icoReactingMultiphaseInterFoam solver. As I understand it, with v1812, dynamic mesh capabilities are built into the solvers. Please correct me if I'm wrong! ******************** dynamicFvMesh dynamicRefineFvMesh; // How often to refine refineInterval 1; // Field to be refinement on field alpha.solid; // Refine field inbetween lower..upper lowerRefineLevel 0.001; upperRefineLevel 0.999; // If value < unrefineLevel unrefine unrefineLevel 10; // Have slower than 2:1 refinement nBufferLayers 1; // Refine cells only up to maxRefinement levels maxRefinement 2; // Stop refinement if maxCells reached maxCells 1500000; // Flux field and corresponding velocity field. Fluxes on changed // faces get recalculated by interpolating the velocity. Use 'none' // on surfaceScalarFields that do not need to be reinterpolated. correctFluxes ( phi U ); // Write the refinement level as a volScalarField dumpLevel true; *********************** Any help would be much appreciated! Thanks! |
December 27, 2020, 05:14 |
Rep Power: 6 |
Hi Bill,
same problem here. Have you already found a solution? Best regards, Florian |
April 7, 2022, 09:19 |
Rep Power: 5 |
Are there any Updates on your Problem?
dynamicmeshdict, melting |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
Sliding / Dynamic Mesh in heat transfer problem | platzhalter | FLUENT | 0 | May 7, 2018 05:25 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 04:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
