[mesh manipulation] falling object simulation with OpenFoam
Old   September 18, 2019, 17:48
Default falling object simulation with OpenFoam
koful is on a distinguished road
Hello foamers.
This is my first entry at this forum. Sorry for any inconvenience.
I need to simulate a free falling object in a medium, like a rock in a water I could not find any dynamic mesh solver for this particular problem. While the object is moving to bottom, it cause a shrinkage on the meshes under it and the simulation crashes eventually.
I used sixDoFRigidBodyMotion. It can simulate the coupled motion of the object but does not remesh the domain or change the topology.
Which dynamic mesh solvers or which meshing strategy should I use? I would be very happy If you can share your comments with me.
koful is offline   Reply With Quote
Old   September 18, 2019, 19:58
CFD USER
CFD_10 is on a distinguished road
Try Overset Mesh. Currently, it is only available in OpenFOAM ESI OpenCFD version (e.g: V1906).
Have a look at this page.
CFD_10 is offline   Reply With Quote
Old   September 19, 2019, 06:17
Yann
Yann will become famous soon enoughYann will become famous soon enough
Check the sphereDrop tutorial, it uses layer addition/removal technique with a sixDoFRigidBodyDisplacement boundary condition to simulate a falling sphere.
Or as CFD_10 suggested, go for overset.
Cheers,
Yann
Yann is offline   Reply With Quote
Old   September 19, 2019, 12:30
Many thanks. I will look at OpenFoam ESI.
Old   September 26, 2019, 01:18
Ted Spencer
tedspencer is on a distinguished road
Many thanks!
the impossible quiz
tedspencer is offline   Reply With Quote
dynamicmeshdict.sixdof, openfoam
Solid object falling in water tank simulation cassini83 CFX 3 August 9, 2021 18:05
Coded function object in openfoam v5 kit607 OpenFOAM Post-Processing 3 September 29, 2020 16:43
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFoam Airfoil simulation - replacing Fluent with OpenFOAM shereez234 OpenFOAM Running, Solving & CFD 1 November 3, 2015 04:54
Is OpenFOAM capable to simulate a floating object with variable density? Idosar OpenFOAM 0 September 29, 2015 17:13
