[snappyHexMesh] Split patches along feature lines
Old   September 17, 2019, 08:58
Default Split patches along feature lines
Felix
foaminifera is on a distinguished road
I am looking for a solution how to split a given STL-file into separate patches along feature lines. The STL-file defines the domain to be meshed, which is a volume with curved boundaries and a few "sharp" edges (feature angle <150°) that are correctly handled by snappyHexMesh after running surfaceFeatureExtract.
I need these individual patches to perform extrudeMesh, for example, with different settings for each patch.
Is it possible to use output from either surfaceFeatureExtract or snappyHexMesh or from other tools to get information such as
- the boundaryMesh consists of n separate patches
- patch number 1 contains faces f1,f2,f3...
- patch number 2 containes faces f101,f102,f103...
- patch number n contains faces f901,f902,...?
Thanks
Felix
foaminifera is offline   Reply With Quote
feature angle, separate patch, surfacefeatureextract
[Other] 2D adaptive Mesh Refinement baco OpenFOAM Community Contributions 80 August 14, 2022 15:18
Rotating Mesh, errors in Cyclic AMI interface WhiteW OpenFOAM 2 September 26, 2016 10:12
Ensight split part by feature angle HHOS EnSight 1 September 6, 2016 22:20
[cfMesh] missing feature edges of coplanar patches when using surfaceFeatureEdges (cfMesh) cutter OpenFOAM Community Contributions 1 August 20, 2015 17:47
Split Patches SteffenLehmann OpenFOAM Pre-Processing 0 November 7, 2012 10:40
