August 10, 2019, 17:46 |
Deleting stl solids
Chris Harding
Rep Power: 10 |
After running <cat *.stl new.stl> and <surfaceAutoPatch geometry.stl output.stl Angle> on my stl geometry, I have 600 solids. Some of the solids are faces in areas that I don't need.
As an example, I have asymmetric diffuser that has a face at it's exit point before going into nozzle geometry. Can I edit the stl file to delete the "face"(solid)? I am thinking of deleting because I don't know how snappyHexMesh will handle the solid, and I think it would be wrong to try and name the patch in snappyHexMesh. |
snappyhexmesh, stl, stl solids |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 07:01 |
[ICEM] STL file! How is it useful? | bidi | ANSYS Meshing & Geometry | 0 | December 26, 2016 22:33 |
[ICEM] Work with imported STL geometry | KateEisenhower | ANSYS Meshing & Geometry | 2 | July 9, 2015 11:46 |
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh | Irish09 | OpenFOAM Meshing & Mesh Conversion | 9 | April 7, 2012 09:50 |
single STL or separate solids for heat transfer | Anastasia | Phoenics | 0 | November 5, 2007 07:57 |
