[snappyHexMesh] ANSA adjoint sensitivity, shape morphing
Old   August 7, 2019, 10:33
Default ANSA adjoint sensitivity, shape morphing
Andrew
Astan is on a distinguished road
Hi guys, i am new in the use of ANSA.
I have looked on the internet but i haven't found any help to my problem so i decided to write here.
I need to use the morphing function of ANSA, i would like to ask you for an information.
I have performed my RANS and Adjoint simulations with openfoam, and the mesh has been done with SnappyHexMesh.
I know that ANSA needs the sensitivity log from openfoam, but also the mesh in order to associate each entry of the sensitivity log with the respective node in the mesh.
How can i load the mesh performed with openfoam into ansa?
Or, if this is not the correct way to procede, how can i load my stl / step model in order to perform the sensitivity morphing?
Thanks you in advance for any answer i really appreciate any suggestion.
Astan
Astan is offline   Reply With Quote
ANSA adjoint sensitivity, shape morphing Astan ANSA 4 August 20, 2019 20:04
adjoint sensitivity unphysical noise propagating upstream in supersonic flow tomp1993 SU2 Shape Design 1 May 15, 2018 14:22
Shape optimization doesn't converge - Adjoint log file JPBLourenco SU2 Shape Design 0 December 11, 2017 09:41
hard to convergent with SU2 4.0 for Euler adjoint Xianguu SU2 1 July 14, 2015 18:09
Shape Sensitivity robyTKD SU2 Shape Design 3 June 13, 2013 20:05
