[mesh manipulation] ImproveMeshQuality
Old   August 6, 2019, 09:32
Default ImproveMeshQuality
Carlo_P
Carlo_P is on a distinguished road
Hey Foamers,
I did a mesh using CfMesh.
Than I tried to improve it using "ImproveMeshQuality".
In the end, I had a worst mesh.
Here you can see the checkMesh file:
before:
Max cell openness = 7.35622e-16 OK.
Max aspect ratio = 29.7317 OK.
Minimum face area = 3.92408e-13. Maximum face area = 1.47856e-07. Face area magnitudes OK.
Min volume = 1.60163e-18. Max volume = 3.43724e-11. Total volume = 3.3578e-06. Cell volumes OK.
Mesh non-orthogonality Max: 84.9321 average: 12.8083
*Number of severely non-orthogonal (> 70 degrees) faces: 309.
Non-orthogonality check OK.
<<Writing 309 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
***Max skewness = 4.04614, 2 highly skew faces detected which may impair the quality of the results
<<Writing 2 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 1 mesh checks.
after:
Overall domain bounding box (-0.0244538 -0.00600789 -0.0060014) (0.268829 0.0361308 0.00600139)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-3.56984e-17 -1.29466e-16 -2.01585e-15) OK.
Max cell openness = 4.85654e-16 OK.
Max aspect ratio = 41.771 OK.
Minimum face area = 1.25284e-12. Maximum face area = 1.65683e-07. Face area magnitudes OK.
Min volume = 1.20562e-18. Max volume = 3.30891e-11. Total volume = 3.3578e-06. Cell volumes OK.
Mesh non-orthogonality Max: 79.9838 average: 18.2811
*Number of severely non-orthogonal (> 70 degrees) faces: 797.
<<Writing 797 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
***Max skewness = 7.31313, 6 highly skew faces detected which may impair the quality of the results
<<Writing 6 skew faces to set skewFaces
End
Do you have any idea in waht is wrong?
Thanks a lot,
Carlo
Carlo_P is offline   Reply With Quote
Old   October 11, 2019, 10:34
chen112p's Avatar
Junting Chen
chen112p is on a distinguished road
I am seeing something similar - a lot more non-orthogonal faces.
chen112p is offline   Reply With Quote
cfmesh, mesh quality, meshing 3d, orthogonal quality
[cfMesh] improveMeshQuality student666 OpenFOAM Community Contributions 0 May 30, 2017 02:49
