[snappyHexMesh] blockMeshDict Geometry And snappyHexMesh
Old   August 4, 2019, 03:50
Default blockMeshDict Geometry And snappyHexMesh
Chris Harding
HappyS5 is on a distinguished road
Most of the information I see with respect to snappyHexMesh is the use of .stl files as geometry.
I am curious if blockMeshDict geometry creation can be used for the geometry requirements of snappyHexMesh?
Also, I will be meshing the interior of a diffuser. How can I use blockMesh to mesh interior of the diffuser if I must use an STL file?
HappyS5 is offline   Reply With Quote
blockmesh, mesh geometry, snappyhexmesh
[snappyHexMesh] SnappyHexMesh won't snap to geometry (external flow) JTDN OpenFOAM Meshing & Mesh Conversion 4 July 1, 2019 08:17
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 06:26
opensource geometry for snappyHexMesh Naresh yathuru OpenFOAM Pre-Processing 2 March 9, 2015 04:18
[snappyHexMesh] snappyHexMesh keeping internal geometry ThibaudB OpenFOAM Meshing & Mesh Conversion 9 March 22, 2012 16:59
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 20:51
