[snappyHexMesh] Parallel meshing - SnappyHexMesh
Old   July 23, 2019, 11:01
Unhappy Parallel meshing - SnappyHexMesh
Akanksha Rawat
Akanksha90 is on a distinguished road
I am facing a Problem while meshing mmy geometry in parallel mode. I am using Scotch method and at the Point of Removing mesh beyond Surface intersections it gives me error -
[0] [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Global -1 does not belong on any processor. Offsets:4(0 676 1721 1844)
[1]
[1] From function Foam::label Foam::globalIndex::whichProcID(Foam::label) const
[1] in file /home/pawan/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/globalIndexI.H at line 230.
[1]
FOAM parallel run aborting
[1]
[0]
[0] --> FOAM FATAL ERROR:
[0] Global -1 does not belong on any processor. Offsets:4(0 676 1721 1844)
[0]
[0] From function Foam::label Foam::globalIndex::whichProcID(Foam::label) const
[0] in file /home/pawan/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/globalIndexI.H at line 230.
[0]
[0]
[0] #0 Foam::error:rintStack(Foam::Ostream&)[1] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[1] #1 Foam::error::abort() at ??:?
[0] #1 Foam::error::abort() at ??:?
[0] #2 Foam::regionSplit::reduceRegions(int, Foam::List<bool> const&, Foam::List<int>&) const at ??:?
[1] #2 Foam::regionSplit::reduceRegions(int, Foam::List<bool> const&, Foam::List<int>&) const at ??:?
[0] #3 Foam::regionSplit::calcRegionSplit(bool, Foam::List<bool> const&, Foam::List<Foam::Pair<int> > const&, Foam::List<int>&) const at ??:?
[1] #3 Foam::regionSplit::calcRegionSplit(bool, Foam::List<bool> const&, Foam::List<Foam::Pair<int> > const&, Foam::List<int>&) const at ??:?
[0] #4 Foam::regionSplit::regionSplit(Foam:olyMesh const&, Foam::List<bool> const&, bool) at ??:?
[1] #4 Foam::regionSplit::regionSplit(Foam:olyMesh const&, Foam::List<bool> const&, bool) at ??:?
[0] #5 Foam::meshRefinement::findCellZoneInsideWalk(Foam: :Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int>&) const at ??:?
[1] #5 Foam::meshRefinement::findCellZoneInsideWalk(Foam: :Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int>&) const at ??:?
[0] #6 Foam::meshRefinement::zonify(bool, int, int, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&, Foam::bitSet&) const at ??:?
[1] #6 Foam::meshRefinement::zonify(bool, int, int, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&, Foam::bitSet&) const at ??:?
[0] #7 Foam::meshRefinement::getBafflePatches(int, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const at ??:?
[1] #7 Foam::meshRefinement::getBafflePatches(int, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const at ??:?
[0] #8 Foam::meshRefinement::removeLimitShells(int, int, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&) at ??:?
[1] #8 Foam::meshRefinement::removeLimitShells(int, int, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&) at ??:?
[0] #9 Foam::snappyRefineDriver::removeInsideCells(Foam:: refinementParameters const&, int) at ??:?
[1] #9 Foam::snappyRefineDriver::removeInsideCells(Foam:: refinementParameters const&, int) at ??:?
[0] #10 Foam::snappyRefineDriver::doRefine(Foam::dictionar y const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&) at ??:?
[1] #10 Foam::snappyRefineDriver::doRefine(Foam::dictionar y const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&) at ??:?
[0] #11 at ??:?
[1] #11 ?? at ??:?
[0] #12 __libc_start_main at ??:?
[1] #12 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
[0] #13 in /lib/x86_64-linux-gnu/libc.so.6
[1] #13 ?? at ??:?
Anybody knows what is or could be wrong ?
Thanks
Akanksha90 is offline   Reply With Quote
Old   July 31, 2019, 04:06
Carlo_P
Carlo_P is on a distinguished road
Hey,
can you post here the snappyHexMeshDict?
Secondarly, can you move a little your point?
Maybe you are unlikly and the point is on a cell face. This creates problems.
Cheers
Carlo_P is offline   Reply With Quote
Old   November 19, 2019, 09:45
David GISEN
David* is on a distinguished road
I have the same problem using v1812 in parallel. Shifting the locationInMesh did not work. In serial, the mesh is created. The last correct output is
Setting cellZones according to locationsInMesh:
    cellZone : none
[5]
[5]
[5] --> FOAM FATAL ERROR:
[5] Global -1 does not belong on any processor. Offsets:
which is from line 2485 in https://develop.openfoam.com/Develop...ementBaffles.C
Any ideas?
David* is offline   Reply With Quote
Old   March 3, 2022, 08:52
Default Same issue here
Rasmus Iwersen
Rasmusiwersen is on a distinguished road
Anyone with how to resolve this problem? I have the same issue..
Rasmusiwersen is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials denbjornen OpenFOAM Meshing & Mesh Conversion 1 May 25, 2020 12:14
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
[snappyHexMesh] snappyHexMesh Parallel bad size error andrewpomeroy OpenFOAM Meshing & Mesh Conversion 2 April 2, 2018 02:08
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 12:55
[snappyHexMesh] snappyHexMesh in parallel with cyclics tonyuprm OpenFOAM Meshing & Mesh Conversion 1 June 29, 2011 11:43
