[blockMesh] stl detection error when converting blender to openfoam
Old   July 17, 2019, 13:25
Default stl detection error when converting blender to openfoam
shuailiao
shuailiao is on a distinguished road
Hi everyone:
I am modelling empty filling box. I developed a model in blender with two heat sources (0.03m*0.03m) and a spacing of 0.1m between them. I exported to openfoam (trisurface) and I use (25*25*25) in blockmeshdict and refine the region where two heat sources are with 0.01m*0.01 mesh size. But finally I find the spacing between two heat sources are not consistent with what I created in blender as well as the size of heat sources.
Anyone knows what's wrong with it?
shuailiao is offline   Reply With Quote
Old   August 22, 2019, 08:12
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
It is because of the element size. Increase your refinement level. Most probably, your problem will resolve.
Regards
mwaqas is offline   Reply With Quote
blender, stl conversion
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
[CAD formats] Can OpenFOAM convert foam mesh to stl? liying02ts OpenFOAM Meshing & Mesh Conversion 10 December 30, 2018 11:03
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 06:46
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
[Commercial meshers] Problem encountered in converting Fluent mesh to OpenFOAM Mesh sathya123 OpenFOAM Meshing & Mesh Conversion 2 November 22, 2015 04:22
