[snappyHexMesh] Creating multi region mesh for chtMultiregionFoam
Old   July 10, 2019, 15:31
Default Creating multi region mesh for chtMultiregionFoam
Nakos
tclph is on a distinguished road
I am trying to create a simple case where a pipe with a wall thickness is heated while a fluid is passing through it. I would like to use STL file(s), snappyhexmesh, a solid and fluid region, and have layers in one side of the wetted wall. I am happy using snappyhexmesh for a single region, but for this case I am having problems and cannot figure out how to properly do things.
I would some help with setting up my case and STL files so that I can follow the procedure below as done with the shellAndTubeHeatExchanger tutorial. Firstly without addLayers turned on, run:
blockMesh
snappyHexMesh -overwrite
Then turn on addLayers (turn castellate and snap off) and run:
createBaffles -overwrite
mergeOrSplitBaffles -split -overwrite
rm -rf processor*/constant/polyMesh/pointLevel
splitMeshRegions -cellZones -overwrite
My geometry and names for the solid regions in the STL file(s) can be seen in the attached diagram.
Issue 1:
I am not sure what is the best way to organise my STL surfaces in files. One option is to have two watertight STL files, one for the solid domain and one for the fluid domain. This would mean having the wetted wall surface included in both files, and these would contain the following surfaces as per diagram.
domain_solid.stl containing:
solid_outer
solid_xc_inlet
solid_xc_outlet
wetted_wall_to_solid
and the domain_fluid.stl containing:
fluid_inlet
fluid_outlet
 wetted_wall_to_fluid
Is this OK? The other option is to have three non-watertight STL files with the following surfaces.
solid_outer
solid_xc_inlet
solid_xc_outlet
fluid_inlet
fluid_outlet
wetted_wall.stl containing:
wetted_wall
The wetted_wall, wetted_wall_to_fluid, and wetted_wall_to_solid are all the same surface, just with different names.
Issue 2:
Can you please have a look at the snappyHexMeshDict and also createBafflesDict sections below to see what I am doing wrong? Currently my mesh is only created for the solid part eventhough the locationInMesh is inside the fluid region. I am have tried several things but I always get the wrong results in mesh, region names. I've not got far yet to try layer addition.
snappyHexMeshDict:
geometry
    fluid_region_name
        type triSurfaceMesh;
        file "domain_fluid.stl";
        regions
            fluid_inlet          { name fluid_inlet_name; }
            fluid_outlet         { name fluid_outlet_name; }
            wetted_wall_to_fluid { name ww_fluid_name; }
    solid_region_name
        file "domain_solid.stl";
        regions
            solid_outer          { name solid_outer_name;  }
            solid_xc_inlet       { name solid_xc_inlet_name; }
            solid_xc_outlet      { name solid_xc_outlet_name; }
            wetted_wall_to_solid { name ww_solid_name; }
castellatedMeshControls
    maxLocalCells   100000;
    maxGlobalCells  1000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.1;
    nCellsBetweenLevels 2;
    resolveFeatureAngle 15;
    allowFreeStandingZoneFaces true;
    features        ( );
    refinementSurfaces
        fluid_region_name
            level           ( 1 1 );
            regions
                fluid_inlet_name  { level ( 1 1 ); patchInfo { type patch; } }
                fluid_outlet_name { level ( 1 1 ); patchInfo { type patch; } }
                ww_fluid_name     { level ( 2 2 ); patchInfo { type wall; } }
        solid_region_name
             level ( 1 1 );
             regions
                 solid_outer_name     { level ( 1 1 ); patchInfo { type patch; } }
                 solid_xc_inlet_name  { level ( 1 1 ); patchInfo { type patch; } }
                 solid_xc_outlet_name { level ( 1 1 ); patchInfo { type patch; } }
                 ww_solid_name        { level ( 2 2 ); patchInfo { type patch; } }
    refinementRegions
    locationInMesh  ( 0.1 0 0 );
createBafflesDict:
internalFacesOnly true;
baffles
    baffles1
        type        faceZone;
        zoneName    ww_fluid_name;
        patches
            master
                name         wetted_wall_to_fluid;
                type         mappedWall;
                sampleMode   nearestPatchFace;
                sampleRegion fluid_region_name;
                samplePatch  wetted_wall_to_solid;
            slave
                name         ww_solid_name;
                type         mappedWall;
                sampleRegion solid_region_name;
I have attached the whole OF case directory if you would like to look further.
Any help would be much appreciated.
Many thanks,
Nakos
tclph is offline   Reply With Quote
Old   December 8, 2020, 16:25
Diego
DIOD is on a distinguished road
Hi, were you able of fixing this issue? I am having the same questions right now.
If not, hopefully, some of the pros can take a look at this.
Best,
Diego
DIOD is offline   Reply With Quote
chtmultiregionfoam, snapphhexmesh, stl file
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Multi Region Mesh Issues - Star CCM+ Hammerson99 STAR-CCM+ 3 September 27, 2018 00:25
[ANSYS Meshing] Creating a region of fine mesh within 3D fluid domain raven ANSYS Meshing & Geometry 1 August 13, 2014 12:11
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
