July 8, 2019, 10:48 |
Non-orthogonal mesh
#1 | |
Priyanka P
Rep Power: 7 |
Thank you for your reply. I am starting a new thread. So, if I want to handle this non-orthogonality in heatTransfer problem, where I am using chtMultiRegionSimpleFoam, which laplacian scheme should I exactly use? Code:
laplacianSchemes { default none; laplacian(alpha,h) Gauss linear corrected; } Also, should I change this laplacian scheme in all the regions of my case or just the fluid region? Thanks. |
[snappyHexMesh] Snapping problem, non orthogonal faces | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2015 02:56 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
