[snappyHexMesh] surfaceFeatureExtract error- Feature line extraction? |
July 1, 2019, 12:51 |
#1 | |
anu
Rep Power: 7 |
Hi everyone,
I'm attempting to run surfaceFeatureExtract on an STL file, but keep running into an error. I'll attach the full readout: Quote:
I will attach both my STL file and dict file to this post. I'd appreciate any help! Thanks so much. |
July 1, 2019, 21:44 |
Rep Power: 16 |
Assuming it is the same dictionary as the one you posted here Error: Feature line extraction is only valid on closed manifold surfaces?, then it is simply a matter of you removing unnecessary lines in the surfaceFeatureExtractDict. Always pay attention to the error messages. Here your error message is about the missing file surface.nas. So unless you have and need a surface.nas file, there is no point including this. Remove all entries except the one for your STL file and it should be fine. Also, since it looks like you found a solution to Error: Feature line extraction is only valid on closed manifold surfaces?, in everyone's best interests, please post your solution. Otherwise someone else running into the same issues will be left scratching their head. Hope this helps. Cheers, Antimony |
July 2, 2019, 10:43 |
anu
Rep Power: 7 |
Ah, thank you so much! Silly error on my part. And yes, just updating that thread right now.
Unknown function type pressureTools | Dorian1504 | OpenFOAM Post-Processing | 23 | May 25, 2021 09:24 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
