June 27, 2019, 06:22 |
merging two Meshes
Lukas Wünschel
I want to simulate several cases of an airplane with flaps and slats at different positions. I would like to mesh the main wing with the Farfield and use this as my "mastercase" when using mergeMeshes. As slaveCases I want to use the flaps, which I also mesh with snappyHexMesh. Hopefully this way I don't have to re-mesh the mainwing and farfield everytime I change the angle or position of a flap. Well at least this is my idea, but so far I don't know how to properly join those two meshes together. When meshing the flaps in snappyHexMesh and choosing the locationInMesh at a point inside the flaps, I get only a the mesh of the flap. Using mergeMeshes I can get it to the main wing. But this way the simulation won't work. I'm relatively new to OpenFoam so I don't know if there is a way to change position/angle of a part (in this case the flap of the wing) without re-meshing everything, except the area around the flap. If anyone has an idea how I could do this, I would appreciate the help. Thanks in advance, Lukas |
June 28, 2019, 00:30 |
Rep Power: 16 |
Hi Lukas,
One way to do this is to use overset. Look for the tutorials in the ESI version of OpenFOAM which would be OpenFOAM-v1812 Hope this helps. Cheers, Antimony |
ami, mergemeshes, snappyhexmesh |
[Commercial meshers] ICEM - Internal patch appears despite merging meshes | krzychu111 | OpenFOAM Meshing & Mesh Conversion | 1 | December 30, 2018 14:08 |
[ICEM] Merging of 3d meshes | Ali3031 | ANSYS Meshing & Geometry | 1 | November 4, 2014 11:54 |
[ICEM] Merging Hexa Meshes in ICEM | screech1987 | ANSYS Meshing & Geometry | 11 | March 13, 2014 12:45 |
merging meshes | amirr | OpenFOAM Running, Solving & CFD | 2 | July 23, 2012 10:30 |
Merging Meshes | Matteo Giacobello. | FLUENT | 1 | February 16, 2000 10:22 |
