[blockMesh] Editing blockMeshdict in IBM tutorials
Old   June 25, 2019, 07:45
Default Editing blockMeshdict in IBM tutorials
Varun Gadre
VarunG is on a distinguished road
I edited the blockMeshDIct of Pitching plate tutorial in Immersed Boundary Method of Foam Extend 4.0 by changing the number of cells. But after editing I am not able to run this tutorial due to the following error
--> FOAM FATAL ERROR:
Can't find nearest triSurface point for cell 124410, (0.000214286 -0.00225 0.0005). Hit data = 0 (6.95328e-310 6.92949e-310 2.78653e-321) -1
From function immersedBoundaryFvPatch::makeIbPointsAndNormals() const
in file immersedBoundaryFvPatch/immersedBoundaryFvPatch.C at line 1037.
FOAM aborting
Aborted (core dumped)
I need to know what other changes I need to do along with changing the number of points to properly run the tutorial.
VarunG is offline   Reply With Quote
blockmeshdict, foam extend 4.0, immersed boundary method, tutorial
Current status of IBM in OpenFOAM quarkz OpenFOAM Programming & Development 2 January 29, 2020 04:57
[blockMesh] Creating an axisymmetric piston cylinder in blockMeshDict foadsf OpenFOAM Meshing & Mesh Conversion 9 August 23, 2018 08:54
[blockMesh] Tutorials lacking blockMeshDict DiracRules OpenFOAM Meshing & Mesh Conversion 6 May 9, 2018 16:19
Why a different enthalpy of water is used in the tutorials? yun_cn Fluent Multiphase 0 November 2, 2017 05:35
[BEGINNER] Problems running tutorials (incompressible) in OF 2.xx Jaro OpenFOAM Running, Solving & CFD 8 March 16, 2016 08:27
