June 24, 2019, 03:56 |
Adding layers snappyhexmesh
Ashish Tiwari
Rep Power: 8 |
I have been trying hard to increase the number of layers on Ahmed car body. I have read many tutorials and I see that the number of layers is quite low for the tutorial cases I.e. below 5 or 6. I think the Ansys guidelines require at least 10 number of layers. How can one justify his solution based upon small number of layers ? Secondly,Apart from feature angle and maxthicknesstomedial ratio,is there something I should try with? |
openfoam 5, snapphhexmesh |
multiRegionHeater error | ordinary | OpenFOAM Running, Solving & CFD | 2 | June 9, 2020 17:43 |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
[snappyHexMesh] snappyHexMesh not adding layers to a solid | jet_engine | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2016 08:25 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
[snappyHexMesh] SnappyHexMesh doesn't succeed in adding several layers | eti0123456789 | OpenFOAM Meshing & Mesh Conversion | 5 | April 9, 2013 02:36 |
