[mesh manipulation] Dynamic mesh with free to move surface
Old   June 10, 2019, 11:30
Post Dynamic mesh with free to move surface
Gabriel Gomes de Castro
GabsGC is on a distinguished road
Hello Foamers,
I am currently trying to mesh a single piston internal combustion engine. It works with two oposed cylinder heads in a single shaft and I'd like to simulate the combustion chamber processes but am having some troubles with the moving boundary of the cylinder head.
For that I initally ran some MatLab simulation for an idea of the dynamic model from which I want to pull initial movement data for the piston. With this movement data I will use either an oscillating movement or a table for the cylinder head boundary mesh movement.
But after the ignition, would I have to make another simulation to implement a free cylinder boundary that will move solely based on the gases expansion from the combustion? And how would it be possible to consider the pressure from the combustion chamber on the opposite side of the shaft?
GabsGC is offline   Reply With Quote
combustion, dynamic mesh, engine cylinder head
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
