[snappyHexMesh] Use snappyHexMesh for wake refinement
Old   May 27, 2019, 23:09
Default Use snappyHexMesh for wake refinement
kkpal is on a distinguished road
I'm simulating flow around a 2D cylinder using mesh made by Gmsh. Currently I'm using stretching grid in the radial direction. I'm happy with the mesh resolution in the near wake but would like to refine far wake so that it looks like the figure blow.
It is possible to specify a region in the wake and refine only this region by snappyHexMesh?
kkpal is offline   Reply With Quote
Old   May 31, 2019, 08:30
anonymous
simrego is on a distinguished road
Hi!
You can use the refineMesh utility with directional refinement. But it will refine only the hex cells. I think all refinement method will affect only the hex cells in OF.
simrego is offline   Reply With Quote
Old   May 31, 2019, 11:45
Thanks for the tip!
snappyhexmesh, wake refinement
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 03:32
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
