[blockMesh] Problem adding work-piece in front of a gas jet |
May 10, 2019, 11:37 |
George Lindow
Rep Power: 7 |
Hey folks,
I am currently modelling a 2D supersonic gas nozzle and I am trying to add a cylindrical work-piece 2mm from the nozzle outlet. I have the nozzle and the cylinder both meshed but I am unsure whether this is the right method for a 2D case or whether I need to re-do the mesh and make it so the work-piece is represented as a lack of space for the air to flow into. I will copy and paste my blockMeshDict file down below and I would be grateful for any help you can give me as I am very new to openFOAM, I hope I have made it clear what I am trying to do here. If what I have done is correct, I am unsure how to define the frontAndBack of the cylinder as empty to convert it into a 2D circle. Many thanks in advance. convertToMeters 0.001; vertices ( (0 0 0) //0 (9.03 0 0) //1 (9.03 0 -1) //2 (0 0 -1) //3 (0 -3.45 0) //4 (9.03 -3.45 0) //5 (9.03 -3.45 -1) //6 (0 -3.45 -1) //7 (3.635 -17 0) //8 (5.395 -17 0) //9 (5.395 -17 -1) //10 (3.635 -17 -1) //11 (3.5 -18.5 0) //12 (3.5 -18.5 -1) //13 (5.53 -18.5 0) //14 (5.53 -18.5 -1) //15 (3.5 -38.5 0) //16 (5.53 -38.5 0) //17 (5.53 -38.5 -1) //18 (3.5 -38.5 -1) //19 (-1.5 -18.5 0) //20 (-1.5 -18.5 -1) //21 (-1.5 -38.5 0) //22 (-1.5 -38.5 -1) //23 (10.53 -18.5 0) //24 (10.53 -18.5 -1) //25 (10.53 -38.5 0) //26 (10.53 -38.5 -1) //27 //cylinder work piece (5.715 -20.5 0) //28 (4.515 -19.3 0) //29 (3.315 -20.5 0) //30 (4.515 -21.7 0) //31 (5.715 -20.5 -1) //32 (4.515 -19.3 -1) //33 (3.315 -20.5 -1) //34 (4.515 -21.7 -1) //35 (4.515 -20.5 0) //36 (4.515 -20.5 -1) //37 ); blocks ( hex (1 0 3 2 5 4 7 6) (1 1 1) simpleGrading (1 1 1) hex (5 4 7 6 9 8 11 10) (1 1 1) simpleGrading (1 1 1) hex (9 8 11 10 14 12 13 15) (1 1 1) simpleGrading (1 1 1) hex (14 12 13 15 17 16 19 18) (1 1 1) simpleGrading (1 1 1) hex (12 20 21 13 16 22 23 19) (1 1 1) simpleGrading (1 1 1) hex (14 24 26 17 15 25 27 18) (1 1 1) simpleGrading (1 1 1) //cylinder work piece hex (32 33 37 37 28 29 36 36) (10 10 10) simpleGrading (1 1 1) hex (33 34 37 37 29 30 36 36) (10 10 10) simpleGrading (1 1 1) hex (34 35 37 37 30 31 36 36) (10 10 10) simpleGrading (1 1 1) hex (35 32 37 37 31 28 36 36) (10 10 10) simpleGrading (1 1 1) ); edges ( //cylinder work piece arc 28 29 (5.363528137 -19.65147186 0) arc 29 30 (3.666471836 -19.65147186 0) arc 30 31 (3.666471836 -21.34852814 0) arc 31 28 (5.363528137 -21.34852814 0) arc 32 33 (5.363528137 -19.65147186 -1) arc 33 34 (3.666471836 -19.65147186 -1) arc 34 35 (3.666471836 -21.34852814 -1) arc 35 32 (5.363528137 -21.34852814 -1) ); boundary ( inlet { type patch; faces ( (0 1 2 3) ); } outlet { type patch; faces ( (26 17 18 27) (16 17 18 19) (16 22 23 19) (20 21 23 22) (24 26 27 25) (24 14 15 25) (12 20 21 13) ); } wall { type wall; faces ( (1 5 6 2) (0 4 7 3) (5 9 10 6) (4 8 11 7) (9 14 15 10) (8 12 13 11) //cylinder work piece (28 36 36 29) (29 36 36 30) (30 36 36 31) //0 z-axis (31 36 36 28) (33 37 37 32) (34 37 37 33) (35 37 37 34) //-1 z-axis (32 37 37 35) (28 29 33 32) (29 30 33 34) (30 31 35 34) (31 28 32 35) ); } frontAndBack { type empty; faces ( (0 1 5 4) (3 2 6 7) (4 5 9 8) (7 6 10 11) (8 9 14 12) (11 10 15 13) (12 14 17 16) (13 15 18 19) (12 20 22 16) (13 21 23 19) (14 24 26 17) (15 25 27 18) ); } ); mergePatchPairs ( ); |
gas jet, meshing, openfoam |
rhoCentralFoam Negative initial temperature in simulation of gas jet into vacuum | c_underwood | OpenFOAM Running, Solving & CFD | 1 | November 19, 2020 15:45 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
gas jet penetration | shahrbanoo | AVL FIRE | 4 | June 26, 2014 17:06 |
Ideal gas problem | Atze | CFX | 12 | March 20, 2014 16:56 |
COMSOL gas jet | jm | COMSOL | 0 | April 27, 2007 12:38 |
