March 23, 2009, 06:03 |
How to use multiple blocks
Marco Müller
Rep Power: 17 |
I'm trying to simulate the drag of a cylinder in 2D. For generating the mesh in 2D (pictures), I use different grading/number of cells for the "interface" of the blocks. So "patch matching" will not work with this. However, if I use excactly the same grading/number of cells on both sides it still does not work. The internal boundaries arent removed as they are e. g. in cavityClipped tutorial. Another way would be mergePatches, but as I read in other posts that doesnt seem to be trivial for my case?! How can I deal with that problem??? Thank You Marco grid1.jpg grid2.jpg |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 04:13 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 17:14 |
[snappyHexMesh] Meshing multiple blocks | Hanno | OpenFOAM Meshing & Mesh Conversion | 3 | February 17, 2011 13:14 |
