[snappyHexMesh] Different nCellsBetweenLayers in SHM?
Old   April 22, 2019, 12:06
Question Different nCellsBetweenLayers in SHM?
Misael Goicoechea
Misael G is on a distinguished road
Good day everyone,
Currently I am working on a mesh for a ship, so far I have manged to successfully generate a working mesh. However there are some aspects of this mesh that still bother me. One of those is the presence of isolated cells with different refinement level (see picture attached).
I believe this is due to how SHM manages buffer zones between different refinement layers. For my particular case, a refinement region in the shape of a box, the cells seem to be added to either side of the region and the corners have a smaller number of buffer cells. This leaves not fully refined cells in the corners.
I have managed to solve this problem by manually setting the buffer zones as different refinement regions with decreasing refinement level and a nCellsBetweenLevel = 1 setting. However the nCellsBetweenLevel seems to be a general setting for the SHM process and I would want a different nCellsBetweenLevel for the refinement region and the surface.
Does anyone know if this is possible within SHM?
Thanks in beforehand
Misael G is offline   Reply With Quote
castellatedmeshcontrols, isolatedcells, meshing, ncellsbetweenlevels, snappyhexmesh
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. Laika OpenFOAM Meshing & Mesh Conversion 1 September 8, 2016 05:09
[snappyHexMesh] SHM not snapping to some surfaces Swift OpenFOAM Meshing & Mesh Conversion 13 January 4, 2016 02:56
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? ADGlassby OpenFOAM Meshing & Mesh Conversion 18 June 18, 2013 07:07
[snappyHexMesh] troubles with sHM and parallel Tobi OpenFOAM Meshing & Mesh Conversion 1 August 30, 2012 18:54
[snappyHexMesh] sHM with cyclic patch on stl geometry johannesk OpenFOAM Meshing & Mesh Conversion 2 August 21, 2009 10:08
