[Other] How to create inclined mesh in OpenFOAM? |
April 20, 2019, 13:32 |
Md Akter Uz Zaman
Rep Power: 7 |
Hello! I want to create a Mesh around a cylinder using blockMesh dictionary. The mesh should be as shown in the attached image.I tried to figure out using several tutorials in youtube and online but failed miserably. The grid lines should be normal to the cylinder and not parallel to each other. Please help me in order to solve the problem.
April 20, 2019, 17:16 |
Rep Power: 13 |
Hi. Your comment regarding grid lines being normal to the discretized circle while having two distinct mesh zones, seems a bit counter-intuitive.
Your specified separation profile is a horizontal line (representative of ground/ soil plane), hence to avoid violating grid quality parameters, it would conform optimally to the provided boundaries while maintaining the compatible/ matching interface boundary. If you're not simulating mesh deformation (which most likely you are), then methods such as setFields would allow you to have your desired single region mesh (flow around a cylinder) as well as multiphase and/ or multicomponent domain. |
[ICEM] How can I create prism mesh for a 3D domain surrounded by a torus? | lzgwhy | ANSYS Meshing & Geometry | 5 | May 18, 2017 17:10 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
