[snappyHexMesh] sHM not successful with -overwrite |
April 14, 2019, 08:32 |
Joe lee
Rep Power: 8 |
I tried to copy the directories in motorBike as a reference, and use them for the simulation for my own bike model. After modifying the dictionaries, I seperately executed command in terminal as follow:
>> surfaceFeatures >> blockMesh >> decomposePar >> snappyHexMesh I entered paraFoam and the mesh was successfully created as in the figure below. I then tried to make a script similar with Allrun, but just with the meshing processes, namely "Meshrun". The Meshrun script is as follow: -------------------------------------------------------------------------- #!/bin/sh cd ${0%/*} || exit 1 # Run from this directory # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions runApplication surfaceFeatures runApplication blockMesh runApplication decomposePar -copyZero runParallel snappyHexMesh -overwrite ------------------------------------------------------------------------ However, for this script, I could not see the mesh for my model in paraFoam. Only the blockMesh exist, just like the image below. There is no error appeared in log.snappyHexMesh. Does anyone know what might be the possible cause? I could provide further information of my setup if required. Thanks a lot!!! |
April 15, 2019, 07:16 |
Yann
Rep Power: 29 |
Hello Jinjolee,
If you have run this exact sequence : Code:
>> surfaceFeatures >> blockMesh >> decomposePar >> snappyHexMesh Code:
mpirun -np 4 snappyHexMesh -parallel If you run is in serial with the overwrite option, the mesh will be written in constant/polyMesh. (and it will overwrite the initial blockMesh mesh) When running snappyHexMesh in parallel, it works exactly the same way, except the directories 0,1,2,3 and constant will be written in every "processor*" subdirectory. In paraView, you can choose whether you want to load a reconstructed (serial) case or a decomposed (parallel) case by selecting it in the "Case Type" option of the properties tab, before clicking on "Apply". In your case, switching the "Case Type" from "Reconstructed Case" to "Decomposed Case" in paraView should allow you to visualize the mesh generated by your Allrun script. If you don't have the "Case Type" option, you might need to run "paraFoam -builtin" instead of "paraFoam". Yann |
April 15, 2019, 08:31 |
#3 | |
Joe lee
Rep Power: 8 |
April 15, 2019, 08:39 |
#4 | |
Joe lee
Rep Power: 8 |
Is this a poor mesh? I do not know how to identify a "good" mesh. Thanks a lot!! |
mesh, overwrite, parafoam, snappyhexmesh |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 02:56 |
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? | ADGlassby | OpenFOAM Meshing & Mesh Conversion | 18 | June 18, 2013 07:07 |
[snappyHexMesh] troubles with sHM and parallel | Tobi | OpenFOAM Meshing & Mesh Conversion | 1 | August 30, 2012 18:54 |
[snappyHexMesh] Multi Region Meshing with sHM | marango | OpenFOAM Meshing & Mesh Conversion | 3 | March 27, 2012 01:51 |
[snappyHexMesh] sHM with cyclic patch on stl geometry | johannesk | OpenFOAM Meshing & Mesh Conversion | 2 | August 21, 2009 10:08 |
