[snappyHexMesh] fail to create mesh using Allrun
Old   April 13, 2019, 12:24
Default fail to create mesh using Allrun
Joe lee
Jinjolee is on a distinguished road
I am new openFoam user. Currently I am trying to perform a CFD simulation on my cyclist stl model. I am using sMH for meshing. Since I do not know much about openFoam, I copied the motorBike directory as reference. After modifying those Dict files, I first tried to create a mesh by typing these command in sequence:
>> surfaceFeatures
>> blockMesh
>> decomposePar
>> snappyHexMesh
>> paraFoam
and the mesh was successfully created.
However, when I tried further process to the simulation, I followed the command in Allrun script. So I tried to change the command to these this time:
>> surfaceFeatures
>> blockMesh
>> decomposePar -copyZero
>> snappyHexMesh -overwrite
>> paraFoam
and this time, paraFoam crashed and quit, with an error:
--> FOAM FATAL IO ERROR:
Essential entry 'value' missing
file: /home/<username>/OpenFOAM/<username>-dev/run/test/0/p.boundaryField.upperWall from line 11 to line 11.
From function Foam::fvPatchField<Type>::fvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&, bool) [with Type = double]
in file /home/ubuntu/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude/fvPatchField.C at line 97.
FOAM exiting
Segmentation fault (core dumped)
It seems to be something wrong with the boundary conditions or the patches, but I am not sure. Could anyone help me to take a look in it?
I would provide my directories after executing the above commands, so you could just type paraFoam and the error would exist. As my .stl and some of the files are too big for uploading to github, I would upload to google drive instead. Below is the link:
https://drive.google.com/drive/folde...XU?usp=sharing
Thank you very much!
EDIT 1:
I tried to change the wall type in frontBackUpperPatches from noslip to slip, and now I could open the mesh!
Yet I do not know why it works, I hope someone would explain this, Thanks!
Another Problem raised when I run potentialFoam after running patchSummary. PotentialFoam gave errors as follow:
--> FOAM FATAL ERROR:
bool IPstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor
From function static bool Foam::UPstream::init(int&, char**&, bool)
in file UPstream.C at line 112.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::UPstream::init(int&, char**&, bool) at ??:?
#3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:?
#4 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/potentialFoam"
#5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/potentialFoam"
[AdminPC:01241] *** Process received signal ***
[AdminPC:01241] Signal: Aborted (6)
[AdminPC:01241] Signal code: (-6)
[AdminPC:01241] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f144382ef20]
[AdminPC:01241] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f144382ee97]
[AdminPC:01241] [ 2] /lib/x86_64-linux-gnu/libc.so.6(abort+0x141)[0x7f1443830801]
[AdminPC:01241] [ 3] /opt/openfoam-dev/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x126)[0x7f1444a4a1c6]
[AdminPC:01241] [ 4] /opt/openfoam-dev/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x3fc )[0x7f14435e5e8c]
[AdminPC:01241] [ 5] /opt/openfoam-dev/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x8ef)[0x7f1444a7283f]
[AdminPC:01241] [ 6] potentialFoam(+0x2f4b4)[0x7f144862f4b4]
[AdminPC:01241] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f1443811b97]
[AdminPC:01241] [ 8] potentialFoam(+0x3192a)[0x7f144863192a]
[AdminPC:01241] *** End of error message ***
Aborted (core dumped)
Could anyone have a look in it and explain what do these error mean? Thanks a lot!!
Jinjolee is offline   Reply With Quote
boundaryfield, mesh 3d, parafoam, patch, snappyhexmesh 3d
Salome, how to create non-structurd mesh to compound with structured one? sheaker Mesh Generation & Pre-Processing 8 August 11, 2017 15:47
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 06:09
[snappyHexMesh] snappyHexMesh does not create mesh in body volume Illmatic OpenFOAM Meshing & Mesh Conversion 1 July 11, 2016 22:35
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer seal2013 ANSYS Meshing & Geometry 3 October 6, 2013 17:09
