[snappyHexMesh] Snappyhexmesh removes wrong section of the mesh |
Rep Power: 14 ![]() |
Hi all,
I have a problem with shm that I cannot seem to solve. Below you can see my domain. domain.png I managed to mesh successfully the domain with the following snappyHexMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; //or false to de-activate snap true; addLayers false; mergeTolerance 1e-6; geometry { Scaled_domain.stl // STL filename { type triSurfaceMesh; name domain; regions { walls { name walls; } inlet { name inlet; } outlet { name outlet; } } } } castellatedMeshControls { maxLocalCells 500000; maxGlobalCells 2000000; nCellsBetweenLevels 4; resolveFeatureAngle 70; minRefinementCells 0; allowFreeStandingZoneFaces false; locationInMesh (2E-4 2E-4 2.2E-4); features ( { file "Scaled_domain.eMesh"; // file containing edge mesh levels ((0.0 1)(0.1 1)); // level of refinement } ); refinementSurfaces { domain { level (2 2); regions { walls { level (1 1); patchInfo { type wall; } } inlet { level (2 2); patchInfo { type patch; } } outlet { level (2 2); patchInfo { type patch; } } } } } refinementRegions { } } snapControls { nSmoothPatch 5; tolerance 1.0; nSolveIter 100; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } addLayersControls { layers { walls { nSurfaceLayers 10; } inlet { nSurfaceLayers 10; } outlet { nSurfaceLayers 10; } } relativeSizes true; expansionRatio 1.1; finalLayerThickness 0.9; minThickness 0.1; nGrow 5; featureAngle 90; maxFaceThicknessRatio 0.5; nSmoothSurfaceNormals 1; nSmoothThickness 10; minMedialAxisAngle 90; maxThicknessToMedialRatio 0.3; maxThicknessToMedialRatio 0.3; nSmoothNormals 3; nRelaxIter 5; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1.00E-13; minTetQuality -1e15; minArea -1; minTwist 0.05; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; // >0 for fluent compatibility minFlatness 0.5; nSmoothScale 4; errorReduction 0.75; } debugFlags ( ); Below you can see a slice of the mesh obtained using the above dictionary. shm_ok.png However, if trying to refine the mesh by changing the line: Code:
levels ((0.0 1)(0.1 1)); // level of refinement Code:
levels ((0.0 2)(0.1 1)); // level of refinement shm_error.png It looks that in this case shm removes the wrong section of mesh but I cannot understand why is it doing so. There is literally no other modification in the shm dictionary. The error is repeatable and happens consistently. In both cases I delete all previous mesh files and even restart with a new initial block mesh. Any help would be much appreciated. Thanks a lot. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 07:08 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
