[Other] splitMeshRegion problem(cell in multi zones)
Old   April 10, 2019, 11:52
Default splitMeshRegion problem(cell in multi zones)
huangkai
huangkai is on a distinguished road
Hi everyone, I'm a newer studying OpenFoam, and I want to use chtMultiRegionFoam to solve problem about heat transfer from the outside of tube to inner air. I followed other's work and used a "o" mesh methods. Then topoSet air and glass region, next splitMeshRegion. In this procedure, a problem about "cell in multi zones" happens. Dose anyone can give me some ideas about this problem? Maybe this tube mesh generation method is not suitable about this problem? "blockMeshDict" and "topoSetDict" are attached.Thank you!blockMeshDict_topoSetDict.tar.gz
huangkai is offline   Reply With Quote
chtmulitregionfoam, splitmeshregions, toposet
[Other] preserveFaceZones constraint on a multi region mesh ViktorKL OpenFOAM Meshing & Mesh Conversion 5 May 21, 2019 12:45
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? aja1345 ANSYS Meshing & Geometry 0 October 3, 2018 15:22
Building problems with cell zones when reopening Fluent MJ2017 FLUENT 0 October 14, 2017 09:11
multi fluid zones gharika90 ANSYS Meshing & Geometry 3 June 19, 2014 15:19
boundary condition between multi zones for UDS lx33101128 FLUENT 0 May 10, 2011 12:12
