April 7, 2019, 03:18 |
salome mesh checking error
Rep Power: 7 |
Hello.
I want to do simulation of a wedge pipe. I have created geometry in Salome and mesh by ideasUnvToFoam. But when I check the mesh, the error shows like this: Cannot find file "points" in directory "polyMesh" in times 0 down to constant I use simpleFoam/pizyDaily as solver. How can I fix this? Thanks in advance. |
April 8, 2019, 13:09 |
Peter Hess
Rep Power: 17 |
Hello Yihong!
Most properly you are using second order elements. If you do, then try it without seond order elements. As plan B that works for me you can try the following: - Download the script: salomeToOpenFOAM.py from here: https://github.com/nicolasedh/salomeToOpenFOAM and save it to your working folder - Generate the mesh you want to convert and save the *.hdf file (SALOME) - In SALOME mark the mesh you want to export - File -> load script -> salomeToOpenFOAM.py - Wait until the mesh exported. Finished exporting is printed in SALOME console - A new folder will be generated in your case called mesh(_1) and includes the mesh - Copy the mesh folder (polyMesh) to constant Regards Peter |
April 9, 2019, 21:51 |
Rep Power: 7 |
Hi Peter. Thanks for your reply.
I just copy the tutorial containing no polyMesh folder in constant folder. No idea about that seond order elements. |
April 10, 2019, 14:23 |
Peter Hess
Rep Power: 17 |
Hello!
Well, as I understood, you generated the mesh using salome... Am I right? If yes, then you need do deactivate the second order elements, cause the ideasUnvToFoam have a problem converting the mesh to my poor knowledge. Send please the case. Show please the log file of the ideasUnvToFoam. Regards Peter |
April 10, 2019, 20:28 |
#5 | |
Rep Power: 7 |
Could you be more specific about what can I do? And yes, I do use salome.
The log file is as follow: Quote:
Thanks a lot! |
openfoam, salome mesh |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
Gerris software installation | mer | Main CFD Forum | 2 | November 12, 2005 08:50 |
