[mesh manipulation] extrudeMesh deletes baffle cyclicAMI |
Maciej
Rep Power: 7 ![]() |
Hello everyone
i've made quite fine mesh using HelyxOS. It's centrifugal pump with diffuser. I used baffle zone to make cyclicAMI boundary condition. I've set 4 cells in Z axis direction. To provide 2Dcase i use extrudeMesh to make 1 cell in Z axis to put empty BC on ffminz and ffmaxz. But - when i use paraFoam after meshing in Helyx, everything is ok , i see my baffle cyclicAMI, but when i use extrudeMesh , everything is ok, i got 1 cell in Z direction but my Baffle disappeard.... i cant see it in paraView. Do you know why extrudeMesh deletes my baffle? |
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox | manuc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2022 11:36 |
cyclicAMI - kOmegaSST - divergence issue | cyln | OpenFOAM Running, Solving & CFD | 1 | October 5, 2018 10:06 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
Problems using createBaffles to create a 3D thermal baffle | zfaraday | OpenFOAM Running, Solving & CFD | 10 | September 6, 2017 17:07 |
Boundary Layer strange result | fernexda | OpenFOAM Running, Solving & CFD | 14 | January 15, 2015 07:21 |
