[snappyHexMesh] volume mesh without 2d mesh modification |
Mike Lob
Rep Power: 10 ![]() |
Hello there,
I'm trying to simulate the external flow over a car. In order to obtain an high level discretization, I generated an accurate 2d discretisation using ANSA and exported it as a stl file for snappyHexMesh. Is there a way to avoid transformation of this mesh in it? I'm using the motorBike tutorial to start, but all the work done in ANSA is basically destroyed. Thank you! |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
engrid: Internal volume mesh becoming coarser during boundayr layer addition | Arnoldinho | OpenFOAM | 1 | January 22, 2011 04:31 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
