Rep Power: 17 ![]() |
Problems with a "wedge-geometry".
Geometry consists of four blocks, and the file below generates an OK mesh. However, if the resolution in the last block is slightly modified (3 instead of 2 cells in the x1-direction, see the commented line below) the mesh cannot be used - and checkMesh chokes on it. Any hints on how to resolve this issue would be greatly appreciated. Edited: problem not seen using OF-5. Thanks, /jon ############### blockMeshDict ######################### convertToMeters 0.01; vertices ( (0.0 0.0 -0.0) (6.0 0.0 -0.0) (12.0 0.0 -0.0) (49.0 0.0 -0.0) (50.0 0.0 -0.0) (0.0 3.8 -0.006632247790413573) (6.0 3.8 -0.006632247790413573) (12.0 3.8 -0.006632247790413573) (49.0 1.7 -0.002967058222027125) (50.0 1.9 -0.0033161238952067866) (0.0 3.8 0.006632247790413573) (6.0 3.8 0.006632247790413573) (12.0 3.8 0.006632247790413573) (49.0 1.7 0.002967058222027125) (50.0 1.9 0.0033161238952067866) ); blocks ( hex (0 1 6 5 0 1 11 10) (15 9 1) simpleGrading (1 1 1) hex (1 2 7 6 1 2 12 11) (15 9 1) simpleGrading (1 1 1) hex (2 3 8 7 2 3 13 12) (93 9 1) simpleGrading (1 1 1) hex (3 4 9 8 3 4 14 13) (2 9 1) simpleGrading (1 1 1) // hex (3 4 9 8 3 4 14 13) (3 9 1) simpleGrading (1 1 1) ); edges ( ); boundary ( front_wall_0 { type wall; faces ( (5 0 0 10) ); } top_wall { type wall; faces ( (6 5 10 11) (7 6 11 12) (8 7 12 13) (9 8 13 14) ); } outlet { type patch; faces ( (4 9 14 4) ); } wedge0 { type wedge; faces ( (5 6 1 0) (6 7 2 1) (7 8 3 2) (8 9 4 3) ); } wedge1 { type wedge; faces ( (0 1 11 10) (1 2 12 11) (2 3 13 12) (3 4 14 13) ); } axis { type empty; faces ( (0 1 1 0) (1 2 2 1) (2 3 3 2) (3 4 4 3) ); } ); mergePatchPairs ( ); Last edited by KrisT; March 19, 2019 at 04:56. |
InterFoam: Different results in OF5 and OF6 | vatavuk | OpenFOAM Bugs | 19 | January 26, 2021 17:22 |
wallHeatTransferCoeff in chtMultiRefionFoam OF6 not working | mwaqas | OpenFOAM Running, Solving & CFD | 4 | September 17, 2020 12:17 |
Strange STL when using cuttingPlane | C-L | OpenFOAM Post-Processing | 2 | September 26, 2017 05:44 |
[blockMesh] Strange non-hexahedral cells? | maka15 | OpenFOAM Meshing & Mesh Conversion | 3 | May 19, 2016 08:56 |
Strange residuals behaviour | xxxx | Main CFD Forum | 1 | July 13, 2013 14:40 |
