[snappyHexMesh] refineWallLayer vs add layer
Old   March 18, 2019, 13:03
Default refineWallLayer vs add layer
Andrew
Astan is on a distinguished road
Hi guys, i would kinldy ask you for some information.
1) how could i see on paraview the distribution of the layers obtained with "refineWallLayer" in the same way as done with the utility "nSurfaceLayers" when the layers are added with the "layer" option in snappyHexMesh?
2) which is the difference between adding layers with "refineWallLayer" and "add layer" ?
3) does the value of the y+ change when using layers obtained with "refineWallLayer" instead of "add layers" ?
4) which is the best way to add layers? "refineWallLayers" or "add layers"
thanks for the time spent for reading the post
Astan
Astan is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
Add a layer of cells, dynamic mesh or ...? Modisa FLUENT 1 March 12, 2007 03:01
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
